  • Replies 1.1k
i will say that my new cannondale's frame doesn't feel as BULLETPROOF as my giant...
that said
it's a track frame for "road" intentions (but realistically it's just a trackbike with pretty colours)
it's not built for being thrown at walls and dropped out of planes
so i think being that it's only going to get speed and road treatment i think it's a good purchase
fyi - i now have the capo - and it's FKING fast!!!! if there's no wind it's easy to get it up to about 55/60odd km/h if you're down on the drops - i can't remember a time i've travelled that fast without a downslope
so
while i won't say the frame is as tough as the giant
i WILL say that the bike weighs 7kg. and goes like a rocket on rohypnol
and that's what it's designed for =)
and don't bother changing the cassette - it's a DH bike!!! unless you're using it for commuting distances... if that's the case then yeah go for it ... but i would also consider changing the ratio and getting another 8speed - that's what im doing with my dad's bike thanks for the advice marc!
i know a guy who has gone through about 6 road bike frames. snaps the bottom bracket out of them. he doesn't treat them rough, he is just a very strong sprinter. he has used pretty much every major brand and still keeps braking them. it is just a simple fact that there becomes a point where light = weak. at the bottom of the market lighter will usually mean stronger because better materials are being used, but once you get to the top of the market (and in some brands only halfway through the market) they start making them too light. a mate of mine who owns a bmx brand ended up making his frames about half a kg heavier (went from 1.7kg to 2.2kg) and then offered lifetime warranty on the stronger frames because all the lighter prototype frames snapped.
ok so here is a bit of a list of some of the more obscure bike parts that people either don't really know or get mixed up.
bottom bracket: the part of the bike that the pedals attatch to, located at the bottom of the seat tube. this can be both the shell (the part of the frame) or the bearing, etc. some bikes use a cartridge system (bearings and spindle/axle are all in 1 unit), others will use seperate bearings from the spindle.
seat tube: the part of the frame the seat post/pillar goes into.
seat post: the bit the seat clamps to
seat post clamp; the clamp on the frame to stop the seat post moving
seat clamp: the part on either the seat or the seat post to clamp the seat to the post.
head tube: the part of the frame the forks go into
top tube: the top..... errr tube that runs from the seat tube to the head tube
down tube: runs from the head tube to the bottom bracket.
chain stays: run from the bottom backet to the rear wheel
seat stays: run from the top of the seat tube to the rear wheel
dropouts: the piece at the end of the chain/seat stays and at the bottom of the forks that the wheels go into.
steerer tube: the tube of the forks that comes up through the head tube
head set: the bearings that go in the head tube
head stem: the stem that goes from the steerer tube to the handlebars (often mixed up with head set)
rim: the outer rim of the wheel. this does not include the hub and spokes. if you are talking about the rim, hub and spokes, that is the wheel.
freehub & cassette: some wheels use a cassette gear system (8 speed and above, and some of the older 6 and 7 speeds). this is where the cogs slide onto a part on the hub called the freehub body. the freehub body has the freewheel/ratchet mechanism built in to it 9slightly different design on bmx's). this makes the axles stonger.
freewheel: this is when the cogs and ratchet mechanism are all in the one unit and they simply screw onto the hub.
brake levers and calipers: brake levers are the bits on the handlebars, the calipers are the bits that move the pads against the rim/disc
where's your bell? $30 fine for not having a bell when riding on the road
true story
lol
Bell fines... I'd get raped if they caught up with me considering the BigHit has no reflectors, bells, lights, etc on it.
Been meaning to get a honka-hoota for racing though. :thumbsup:
haha my c-dale came without a bell - is that a paddlin on the bikeshop?
i removed my bell from my other bike on account of nobody gives a shit anyway if there's a pedestrian in your way there's about a 99% chance they're listening to the kings of leon on their ipod anyway and can't hear it
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
