hmm, okay then i shall not ever get a fixie.
tsk, i need crank recommendations... my shitmano xt wouldn't stay on anymore. Or does anyone still have those old isis truvativ holzfeller cranks lying around in their garage willing to sell? I loved how those cranks were.
  • Replies 1.1k
i am assuming you have octalink cranks at the moment and not old XT that is square taper? also what gearing are you running? triple, double or single? also shimano octalink and isis drive spindles are different so you can't just swap the cranks over.
I know, i'm actually using the Hollowtech II cranks.
And i'm running on my granny ring.. 26t, and running a 13 or 15t cog a the back.. its currently now a 13t becaue i cbf adding a link back onto my chain.
so you are only running it as a sinlge speed? why not change to a set of bmx cranks? much stronger. i may be able to hook you up with a set of old cranks and a 25t sprocket. all you would need to do is buy a bearing set for about $50
ok, had a quick look at what i have in old stuff. got 1 set of bmx cranks but not really ideal as they have a 22mm spindle so since you are running it with a euro BB set it will destroy bearings pretty quick. the downside to running a bmx crank is that you can't keep the external bb shell which gives you better bearing life. but going to a bmx crank you are getting a much stronger crank and the weight difference isn't that much. if you are worried about it you could always put a titanium spindle in it. and bmx cranks are cheaper than mtb cranks. i looked up the price of a set of xt cranks before and the wholesale price on them is about the retail price on a good set of bmx cranks. and then once you take into account the cost of a sprocket and bb set the bmx cranks would still be cheaper and stronger.
i'm not a big fan of profile cranks. sure they are good, but there is other stuff just as good, if not better at the same price. i'd be going something like the colony colonial cranks.
as for fitting them. it's not harder than fitting shimano cranks really. you install one side of the bearings, slide the spindle through a bit, slide in the spacer then install the second bearing cup, then just plap around with the spacers until you get the right chainline and the right amount of spacers to have the second arm sit properly and have both arms clear the frame.
I've been racing Downhill for a fair while now.
Heres some of my current rides:
Banshee 2006 Chaparral - Custom race bike. Insured for $7k
Skate park/ Jump bike
2008 Eastern Thunderbird
Me in action:
State Champs Eagle On The Hill 2009
Nationals Eagle On The Hill 2008
Mt Torrens 2008
Mt Torrens 2008
Me in action:
Mt Torrens 2008
Mt Torrens 2008
Question, Have you ever landed a jump so hard that you've snapped your bike frame? or any other bike part for that matter?
I want a Cannondale Capo... $1750 one, the one with the Purple grips on the handle bars... MREPS put it up, where is santa when you most need him?
macdog - that bike is not worth $1750. if a shop is quoting $1750 for that bike you're describing they're having a lend of you.
it's worth $1,100 MAX.
it's a 2009 bike, it's clearance now.
anyway
results of my 53km bikerace. i am a retard.
the night before i decided to fully degrease and dry out my entire bike chain,. then re-lube it.
at the start line i noticed my back wheel wasn't sitting right - lube had got into the axle and slid one side of the wheel over. race started - by brakes were scrubbing the back wheel. had to pull over and re-adjust my brakes, this did nothing. so i hit the wheel back to somewhat straight.sliding the other side of the wheel over - causing chain sag..
chain sag and over lubed chain means chain comes off easilly.. so i lost about 5 mins pulled over with my brakes. chain came off 5 times... and i had to ride a bit slower so as not to hav the chain demount.. so in total i would've lost about 20 mins of my possible time - but - that's riding what can ya do
i finished in the 25th percentile of riders with an average speed of 28.9 km/h
very dissappointed witht he overall goings on ie - bike breaking down majorly.. but.. givent he circumstances.. to finish in the top quarter of riders i really can't complain..
EDIT - looks at BIT_SUSS's rides... my money's on NO. haha
Edited by Mr Eps
Are there any bikes with gears that would suite a 6 yr old ?
I road cycle and want my son to get into it, as he loves riding his little bmx.
But with no gears getting up hills is too hard for him.
you can get 20" mtb's that have 6 or 7 gears. whatever you do don't get a 20" with a triple chainring crankset. they don't have long enough chain stays to properly run a triple chainring set so you end up with plenty of chain issues.
you can also get 24" road bikes, but he wouldn't be big enough to ride one at 6. he would only just fit onto a 20" mtb at 6 unless he is very tall.
Then i'll kill my knees!
nah they are no worse than mtb's for knee injury. and gearing is moderate. not too easy but not too hard. i have crappy knees and i had no issues racing my 20". but you could always go a 24" if you are worried about it.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
