umm don't they run a 48T / 16T????
and you want HIGHER?! if you want mroe speed i suggest you upgrade your tyres to vittoria rubino, or if you can afford it - open corsa...the zaffiro tyres run a bit soft and don't have that much puncture protection. rubino and open corsa's have nice TPI casing and kevlar strip. plus they look cool as shit.
as much as i wanna say "support your local retailer" - retail charge between 90 - 110 for these tyres, i pick up a PAIR from ebay for under 70AUD shipped. while it does hurt local industry, i am a consumer and will occasionally favour a "good deal"
and theyr'e in the new colourway too.
macdog for your bike... if you can still find them - ( would take a while) but get the vittoria rubino "celeste" colour. would go nicely with your frame
anyway - congratulations on your purchase you must be very happy with it!!!
bloody oath, cheers for all your help again.
Wheels look good. you reckon $70 each off ebay? mate, WHOLESALE IS THE WAY TO GO!
By the way, fixed gear is fcking dangerous... i dont know how those blokes in the city do it without brakes...
whats your all time favourite bike EPS?
  • Replies 1.1k
i recommend michelin pro race 3 tyres. good for at least 10,000kms unless you skid them. 127tpi puncture resistant casing, light weight, roll well and fitted as standard to a lot of high end bikes. i also ran them on my road bike and never had a puncture and the roads round here are shit. but basically all of those high end tyres are good
as for the gearing, when you say you want higher gearing, do you mean you want it to be easier or harder? if you want it easier, that can be changed much more cheaply than if you want it harder. to go easier would cost you about $20, but to go harder would cost you more. to go easier you could just get a bigger freewheel. but to go harder you need a bigger chainring on the front and may also need a new chain (as the old chain may not be long enough)
can't go any smaller than a 16t freewheel on the standard size thread on a hub. 16t+ = standard size, 13t, 14t, 15t = smaller size hubs with both sized threads are called flip flop hubs. so since the hub is designed to take a fixed wheel on the opposite side to the freewheel i'd say that there is an extremely good chance that it won't take anything smaller than the 16t.
the hubs on fixies generally aren't flip flop hubs. they are generally called "single speed" hubs and will just have 2 threads the same size but one will have a lock ring on it to hold the fixed sprocket on.
so in short i'm saying that you're wrong and ghey
soooooooooo it fits on the flip flop side of the hub... sooooooo you're saying i'm ...right???
.....and coming out of the closet??? =P
Hey Mad, I want it so its harder to pedal, I thought it was only $25 to change the hub at the back? thats what the guy in the bike shop told me anyway... lol
well take a picture of the back hub so i can get a better look, but i'm guessing the guy at the bike shop may be a douche who doesn't know what he is talking about....
actually i think i have a masi catalogue round here somewhere from when i was offered the dealership. will have a look
ok just looked at the specs and it does have the flip flop hub, so you can put a 15t freewheel on the back. you don't even need to take it to the bike shop to do it. just go and buy a freewheel and screw it onto the side that doesn't currently have the freeheel on there. you can leave the old one on there in case you ever want to change back. i would still take the wheel in with you when you get it simply so you can make sure that the freewheel will fit. just don't let them try and charge you fitting as all you do is screw it in by hand then put the wheel back in the bike and hop on the bike and pedal and that tightens it up.
while you can get a freewheel for about $15 (that's what i sell them for but i'm guessing they will be more where you are) i would recommend going to a better one. i recommend the ACS claws freewheel. they will be the right width for your chain and are pretty much the best freewheel on the market. they go for around $40. they are a much nicer freewheel. they have a better pawl system (the pawls are the little things inside that lock in when you pedal) and a tighter spring. and because of this they are much louder and sound a bit like a fishing reel, LOL
as for the bike, it looks to be decent spec'd for $1400rrp
Cheers for the info mate, your a legend.
What bike are you riding at the moment?
The only other thing i was curious about when i bought was is 58cm big enough for someone 6ft 5? The bloke said your meant to sit up higher? is that true or just some bullshiteee to get a sale?
it's more to do with the length of your arms - have you got flat or drop bars??
it should be about the right size - i'm probably and inch or so shorter than you and i ride a 58cm
either way - you've BOUGHT the bike now so too bad so sad if it's not the right fit =P
i can't fathom why you'd want to make it harder to pedal though - i've often toyed with the notion myself but my bike goes plenty fast without it
get fatter tyres if you want harder to pedal - it'll slow you down and piss you right off - seems like that's what you want haha
but yes - masi's are a good bike with good frames, nice n tough! enjoyyyyyy
Yes, i've finally got cranks.
A good friend of mine sent over another pair of XT hollowtech cranks for me to use for the time being, i've tightened the bolts to the max, i dont have a torque wrench, so i wouldn't know whats 12Nm. So i reckon my arms should have enough torque.
I just hope it won't loosen like the previous cranks did. Finally i can ride.
I have an old mongoose frame, was going fix it up for my son, but the bike shop said it wasn't worth it.
Anyone know about mongoose?? They worth anything these days?
Yeh I own a mongoose, fantastic bikes in my opinion. I own a mongoose brawler which I bought in June, I owned a mongoose sniper before that. I use the brawler for dirt jumping, can really take some hard hits. Here it is:
the brawler is a low end bmx bike. not what i would recommend for serious riding. mongoose make some good bmx bikes, the brawler (or the sniper for that matter) isn't one of them. sure they are good for the money, but as far as quality goes, there are many better bikes around, but they will also cost you a bit more. there are a few things that let the brawler down as far as quality goes. they are:
single wall rims
loose ball bearing hubs (looseball hubs aren't that good. i'm regularly fixing them)
doesn't have a full cromo frame (makes it weaker and heavier than a full cromo frame)
plus a few other little things. but most of these are common things with bikes of that price range, and the only way to get the better stuff is to spend more money.
  • 5 weeks later...
apparently my bike got stolen.
i dont know when, i reckon over the xmas period, but i cannot be sure, because i just found out.
I'm sad, just when i got the cranks fixed up properly..
I have a giant acid frame in the garage, they left that alone. But i dont really like dirtjump frames, so i'm unsure, i considered either quitting bicycles, or build a trials bike from weird parts left over in my garage.
http://cgi.ebay.com.au/Planet-X-New-Jack-F...=item3a56cc6a01
i used to ride this frame, should i get it again, i realise its old, but despite the longish chainstays, it was pretty easy to stay on the rear wheel.
not so fun for 180s though... just thinking..
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
