Who is running a Garrett T51r??? Im looking at getting one for my 25/30 http://www.horsepowerinabox.com/HPIAB2/prod511.htm
Just want to know what peoples opinions are about this turbo. I have a nos kit to help bring it onto boost and the car doesnt get driven ofter just more of a toy for the drags and dyno days.
https://www.sau.com.au/forums/topic/233101-garrett-t51r/
  • Replies 70
Not to sure on the specs of this turbo but do not be lead to believe that garret turbos are the same spec as HKS though the add does state that they are similar so is not claiming they are the same. But many people will try and tell you they are. I can tell you without a doubt that they are not and the HKS turbo will outperform the eqivelent garret every time. Not taking anything away from the garrets as they are a very good turbo but i would be chaseing priceing on genuine HKS as a comparrison.
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4087602
I have no idea what they are going on about with the "Garrett T51R" thing, sick of inbetweeners making up random names and confusing people with them. The closest I know of to a T51R is a Garrett GT4202R, nice turbo.
If you are going that big i would get the SPL. Nothing beats the sound of that turbo, you will love it.
GT4202Rs sound exactly the same, dirty big turbo with anti-surge housings will do it every time :D
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4087939
what about something like this then???
Garrett GT4594R Turbocharger $2536
Horsepower: 800hp-1100hp
Compressor Housing A/R -: 0.60a/r
Turbine Housing A/R -: 0.91a/r, 1.05a/r, 1.22a/r or 1.40a/r
Turbine Hsg. Attachments: Inlet: Standard 4-bolt T4 flange
Turbine Hsg. Attachments: Outlet: GT42/TA45 flange (6-bolt)
Oil Inlet - : Inverted Flare 7/16-24 thread
Oil Drain - : Standard 2-bolt T4 flange
Bearing Type: Dual Ball Bearing
Cooling: Water Cooled Centre
Wastegate: None (Use with External Wastegate
There are just way to many options for the same size turbo. I want something that will be on full boost around the 6k mark on a built 25/30 running nos
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4087960
So for those who think the Garrett GT4505 is different to the HKS T51R SPL, can you tell me what exactly is the difference?
And why should this guy pay $5350 instead of $2400 for those differences?
You're kidding yourself if you think the SPL will outperform the Garrett. They are the same turbo
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088238
HKS turbo kits come with everything u need
garret u have to piece together yourself
the turbos alone the HKS spools marginally quicker (you wont notice it in real life)
Garret develops HKS turbos and sell the rights to them, then make a tamer versions themselves as far as i know
the extra 2.6k is for the bagding HKS T51R KAI or SPL
brilliant turbo kits, i have one right next to me :(
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088349
OK a GT4508R is quite different from a T51R SPL, HKS have only JUST released a turbo comparative to the GT4508R and that is the T62R which they showed the prototype of at the last TAS. A T51R SPL is so similar to a GT4202R that there is no point in my opinion in paying the extra for the T51R. A chap I know has run a T51R SPL and a GT4202R on very very similar engine setups and he got slightly more power out of the GT4202R and both seem very similar spool - the GT4202R setup was on a manual trans car vs auto for the T51R. In both cases I believe the turbos had been run to the point they weren't going to really make any more power (around 1000hp).
The car that had the T51R SPL on it is in the process of getting upgraded to a GT4508R, will be very interesting to see the results of that.
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088358
Part of that is true.
Their kit only comes with gaskets and a couple of fittings and some bolts. You can buy these as kits from Sonic.
So we're up to $50-$60 in gaskets/bolts etc.
The Garrett turbo is actually more responsive than the HKS one.
The HKS T51R SPL uses exactly the same cartridge and make a small change to the compressor cover. They also use Vband on the turbine housing instead of TV flange on the garrett.
Garrett makes the turbos for HKS, HKS do some development on housings. Sometimes they change a wheel dimension but essentially remain very much the same. The HKS T51 SPL was designed to make a true 1000hp whereas the Garrett turbo will probably only get you up to 980. That is why the Garrett version remains more responsive.
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088363
I wasn't talking about a 4202 or a 4508.
I said 4505.
It is the equivalent of the HKS T51R SPL. Garrett do not list it on their site but the cartridge number is: 709647-5005
I am holding it right now...mmm it is sexy.....and friggin heavy
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088367
MODEL GT4502R T51R
TURBO PART # 774087-1
COMP HOUSING 443209-28
COMP A/R 0.72
COMP WHL INDUCER mm 76.58
COMPRESSOR TRIM 56
ADAPTOR N/A
CHRA 709647-5
TURB WHL EXDUCER mm 71.42
TURBINE TRIM 76
TURBINE HOUSING 441284-127
TURBINE A/R 0.91
MTING FLG GASK. SIZE 409038
ACTUATOR N/A
ACTUATOR PRESSURE N/A
ALTERNATE TURBO SB8009
APPROX H.P. 1000
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088371
MODEL GT4502R T51R
COMP A/R 0.72
COMPRESSOR TRIM 56
ADAPTOR N/A
CHRA 709647-5
TURBINE TRIM 76
TURBINE A/R 0.91
ACTUATOR N/A
APPROX H.P. 1000
Holy crap, sorry my bad- I had assumed going by how often people mess up and quote incorrectly (and its way more often than not) I thought you may have just miss spelt or been misinformed. Ok thats an awefully neat little turbo there which I wasn't aware of, yes - very very T51R SPLish. Nice! Learn of something new every day.
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088392
Yes the whole HKS kit uses V-bands
from the turbo to manifold
manifold to wastegate
and the dump pipe all utilise the V-band
oh the screamer too :sleep:
still in the process of collecting parts for the rb26/30 build up
hopefully make 500awhp+ with decent response on the KAI
i think its a fair bit smaller then the SPL
Edited by R32 Driver
https://www.sau.com.au/forums/topic/233101-garrett-t51r/#findComment-4088711
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
