I'm sure a lot of you have seen my car anyway... But here is some pics:
Can View more at http://www.sgv35.com
Beautiful car... maybe you should put your interest down here:
http://www.skylinesaustralia.com/forums/topic/393123-qld-photoshoot-by-tangcla/
I just picked this car up the other week, some of you may have seen it around Brisbane before with the previous owner. Most of the shots are from a Forge photoshoot before I got the car.
20" Forge wheels, Brembos, leather, bose stereo, coilovers, exhaust and a few other bits and pieces.
Overall really happy with the car. Just have to sort out some slight scrubbing problems on the front when hitting bumps and see if I can get the screen fixed. No picture showing up so I can't see what I'm doing...
Has anyone experienced any headlight problems with these lights? They don't seem all that bright on low beam?
Also I seem to be getting a "tick" noise when taking off and sometimes when changing gears. Sounds like it is coming from the rear brakes?
Hey Goodys, nice ride. Yeah ! Mine developed a ever so small "clicking" at around 60,000klms. Its so faint that even my mechanic cant work out where its from. I m pretty sure its a cv joint to the diff. I notice it when I first take off (sometimes 2nd gear), but definitely when you reverse then go forward.If it gets louder I will investigate further , but too minor to worry about now.
As for lights- the only issue with all skylines Ive had is the front passenger side parking buld. Usually just give it a bump & its good !
I just changed to LED'S as well as interior & wow thats good bang for the bucks!
Thanks for the info mate, I have a hoist handy so might have a look around and see if I can find anything near the CV's.
I just got home from a drive and decided to actually have a look at the lights while they were on and it seems I have 3 out of the 4 low beam lights out haha. I think this might be my problem. I will hopefully pull them out tomorrow and see if they are stuffed.
For anyone interested the wheels are 20x10 -0 with a 5mm spacer so effectively -5 front and 20x11.5 -0 rear. Not sure what the camber settings are or if there is much adjustment in them. Need to bring them in a little bit to avoid some scrubbing on bumps.
Also which interior bulbs/LED's did you replace? Any pics?
Yeh sounds like you have a short somewhere in the wiring. Replaced the Parking lights, Interior -headlining and door lights, boot and number plates also.
Just need to buy the clear indicator lense now. (had the car 4&1/2 years and just woke up to it now ! lol)
Anyone recommend somewhere in Sydney that sell them ??
I will post some pics when I do these.
Had a mess around today and it looks like it is just the RHS low beam bulb which has blown. It does not actually look blown but after connecting it to a battery I am still getting no light.
Will going to a "whiter" light give a bit better vision? How it is now I can't really see all that good on low beam..
Right now they are more blue than anything.
The lights are after market but not sure exactly what. Pic attached.
It's the rear axle bearing.. Very common problem with v35 Skylines.. It's nothing major.. Just an annoying sound
Edited by Megahowler
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
