so, put the car on the hoist the other day to put on some R33 calipers and the bolts are different. old bolts too big for caliper, R33 bolts too small for mounting bracket. what have people done to overcome this problem?
D.
lol. i'm in the same boat as you at the moment. over the last few weeks i've been sizing them up to see what changes are needed and this is one of them. i've read on here that 33 calipers bolt straight onto S1 stagea's, is yours a S2, mine is, and it wont bolt straight up. The Stagea bolt is a fine thred M14 and the R33 a fine thred M12 (i haven't put a thred gauge on it yet to check the pitch). I've been looking at two options.
1. Drill and Tap the R33 caliper out to M14, it looks as though there is enough meat in the threded inset to do this, need to check properly though.
2. Turn up a small sleave in the lathe that will take the hole in the Stagea Hub for the caliper down to 12mm so the caliper locates properly. if i do this i'm sure i'll need longer bolts aswell.
sorry i dont have a definate answer of "this is what to do", but just a couple of ideas i've been looking into.
i'd personally run sleeves as it's a non permanent option if you ever decide to revert/sell the calipers
i've got a pair of BNR34 brembo calipers and pads for sale here if anyone is interested? the mount holes on the calipers are M14 :rofl:
I just used the 33 bolts, ran some race tape around the bolt shank to locate them in the centre of the holes, and did them up nice and tight. Has been on for about 18 months of thrashing so far without problems.
i've got a pair of BNR34 brembo calipers and pads for sale here if anyone is interested? the mount holes on the calipers are M14 :D
depends on the price !!
Ive kept stock calipers all round
got Maltech SS braided lines at 4 corners
front DBA slotted rotors
master cylinder stopper
bendix advance and heavy duty pads
Went down to the local reece plumbing, found a copper sleve that was the right diameter. cut it down, bashed it in, filled it flush.
perfecto! :D
yeh i've been told R34 stuff will bolt straight up but i got a full set of 33 calipers and rotors nice and cheap.
dazza, was it just copper pipe or an actual sleeve for something?
also, i'm getting an R33 master cylinder with my brakes, is it worth putting this on too? is it any better better/different?
D.
from memory it was a straight joiner with a slight indent in the middle, around 35 mm long to suit 1/2 inch copper pipe. Get two and cut them in half , then put a straight cut along the length of all of them with a thin hacksaw blade. That will give you enough play to get them in. hope this helps.
i have an S2 and the bolts that came with the 33 callipers were the right size but i have a RWD so what would i know cause most of u guys have AWD's and the two cars just seem to be worlds apart from what fits and what doesnt. i was thinking of trying some R34 front cause they are bigger and will look better inside my 18's but if the bolts are a different diameter then i cant be stuffed as there isnt really much of a performance gain between 33 and 34 brakes.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
