  • Replies 518
BDO lineup 09
Neil Young
The Living End
Arctic Monkeys
My Morning Jacket
Sneaky Sound System
Pendulum
Bullet For My Valentine
Cut Copy
TV on the Radio
Cog
Simian Mobile Disco
The Grates
Birds of Tokyo
Youth Group
The Ting Tings
TZU
Tiki Taane
Eddy Current Suppression Ring
and… The Prodigy
http://www.inthemix.com.au/news/aust/39795...009_first_round
Good Vibrations Festival 2009
Fatboy Slim
The Presets
The Roots
Deadmau5
Sam Sparro
Roni Size Reprazent
Chromeo
Stanton Warriors
The Potbelleez
Kid Kenobi & MC Shureshock
Micky Slim
Yelle
Wale
The Cuban Brothers
Rico Tubbs
Mike Relm
I have been waiting to see Fatboy Slim Live since I was 13!!
And sheng, Ill be at Plump and Soulwax too!
Ill be at 2many dj's in stead of dizzy though
im gonna spend a bit of time with Dizzy until I get bored of it then go to 2 many
yeah i just want to hear his red hot popular song and then ill be dizzeed out... hopefully he does not play it last
the GV lineup makes me excited!
Breakfast at mine fockers early like 9am... never too early to can on!
GOLDFRAPP maybe
PLUMP DJs def!
METRO AREA def!
FAMILJEN DEF DEF - his album is pumping!
VAN SHE maybe
SOULWAX maybe - SO f**kING AWESOME
DIZZEE RASCAL DEF!
DIPLO DEF!
DOES IT OFFEND YOU, YEAH? def!
FAKE BLOOD def!
ELEKTRONS def!
DRAGONETTE maybe
GRAFTON PRIMARY DEF DEF!
PEACHES maybe - AWESOME
JESSE ROSE DEF!
YUKSEK maybe
BOY 8-BIT DEF!!!!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
