  • Replies 518
2-10 thats a short festival bastards
SET-TIMES & MAP
HARBOURSIDE DANCEFLOOR
2:00 Illya
3:00 DJ Sneak
5:00 Aston Shuffle
6:00 Van She Tech
7:00 Feadz
8:30 Felix Da Housecat
10:00 close
TREETOP STAGE
2:00 Ember
3:30 RoShamBo
5:00 Learned Hand (Funktrust)
6:15 Illya
7:30 Paradise Lost DJs
8:45 MoFunk
10:00 close
So who we guna see when n shit
so like yeh. this chick at my work bought 3 tickets, they were $350 each. and she hasnt gotten them yet. then they said to meet them out the front of Harbourlife and they will get them then..
doooooooooodgeeeeeeeey
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
