  • Replies 518
yeah use texta write loose patrol on the hat n shit
nuh i reckeon its underworld, OI
if its preset, im gonna jump on them n stab them in the eye!
Was in Melb for Summerdayze and we got underworld..
Capped it of with Born slippy :D:(:)
Im psyched for tocadisco!
Got my tickets for future today!
Doing to Digitalism this friday - Feild day was not enough!
And just for shits and giggles, the 7-11 show on friday night for Sydney Festival.. its free! :blush: And Ajax is awesome!
Jan 10th - Fuzzy will be hosting two stages located in College St and Macquarie St from 7pm -11pm with performances from Santogold, A-Trak, Busy P, DJ Mehdi, Ajax + more! With road closures throughout the city this is a unique opportunity to take the city back and show Sydney how we like to party, Fuzzy style!
I might head in with my camera and do the photography thing
Will definetly check out Fuzzy thing at Syd Festival this saturday, was a bit let down by Field Day, not sure if i was just hung over or Parklife was just that much better.
No no.. It was awesome!.. I have no idea why.. but it kicked arse.
Last time I saw Busy, he blew my mind!.. SO im pumped!
field day was great, lots of sun, lots of drinks and you could find your mates easily, wasnt too big and mobiles work
parklife was meh
harbour was great, even though the acts werent the best the atmos and loc made up for it...
we love sounds, future and goodvibes me anyday biatches!
GTS4wd - as good as say chemical brothers? that almost beat daft punk in all awesomness
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
