  • Replies 588
Posted Images
yeah we were going to drive home but just thought we wud stay :bunny:
i wasnt calling any one on here chicken shit btw haha just the general population on SA haha
oh yeah my gfs been writing these posts any ways
is it too late to enter? starting to think maybe i should tag along for this, could be fun just gota make sure i get some new tyres :banana:
dosnt matter if not i have some uni assignments i should prob be attending to
Edited by Inline 6
I know its late but is there any chance of entering still or on the morning ?
i totally forgot about it till now? and my R34 could make its first show....wont win anything but shiny as hell still..lol
and haven't met many of you in the club..plus i'll be taking all the camera gear for photo shoot etc.
if someone can let me know . cheers
Troy
the cut off for entries was friday just gone,
but call mark, 0408 212 390...
tell him you will be with skylines australia, and he should make an exception, as we have 9 entrants.
just called mark, looks like he has some room for late entries if anyone else wants to go, give him a ring.
so if you dont mind an old tag along to join you, i'll bring up the R34? and camera gear.
can someone pm me with meeting details for the drive up sat ?
cheers
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
