lol shhhhhhh craig.
pretty sure i aint telling you anything anymore either...cos it turns out whatever i tell you gets passed onto adam anyway :(:P haha
anyway ya pics are up that you requesteddd :kiss:
  • Replies 588
Posted Images
just got an email from mark..
he thanks us all for entering and supporting the royal flying doctor service.
and also advised me that the show will be held every 2 years, and will be
known as the ''COPPER COAST SHOWN 'N DYNO
he also asked for feedback, so if you have something you think they could improve on,
post it here so i can reply to his email
e.s.e.p (said in beached whale/kiwi accent) :D
yeah i was happy enough with the way the whole event was run... i thought the country carnies charged to much for there rides but i think my daughter got her monies worth for $5 :( maybe i just forget how much shit really does cost :D
Charmaine, this pic is fckn awsome!
32-33-34 all in one perfect pic... love it mate!
http://fc01.deviantart.com/fs36/i/2008/281...lyhyperlite.jpg
+1! that photo is brilliant!
the blue 32 is very photogenic... :D
same.. peeling bad!
that blue 32 is my mates, thats all it is, a fairy paint job, and he thinks its the best 32 ever :D
he was devo he didnt win best jap or best paint lol...
im glad he didnt win, cos he would have been a sore winner if ya know what i mean
EDIT: he also only had those plates on for the show
theyre not even registred to a vehicle anymore
can someone say POSER?
Edited by craig R33
i think i still had my auto salon 07 sticker on at scs last year haha.
him winning best jap.. chrome and white walls.. puhleeese! its more korean/china spec than JDM.
anyway yeah i rate the show. its like scs before it went shit. i was at the very first show 2 years ago and prob at the next one in 2.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
