Formal challenge as posted in the Supra forums
http://www.skylinesaustralia.com/forums/Sk...ha-t233629.html
Of all the events we can challenge the Supras to this has to be the one we have a good chance of winning. The GTS-T's have a great advantage around the track due to their light weight.
We need a good show of Skylines, have a bit of Skyline pride, save up, come out and whip some Supra butt. You don't need to be the best to win a trophy either.
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5.
6.
7.
8.
9.
  • Replies 133
Currently attending
1. a20089
2. Michelle
3. Mark
4. Steady Eddy
5. Bullet32
6.
7.
8.
9.
I'll be there if my car is ready, its still in pieces after Wakefield but I hope to have it up and going again within a month... (hopefully) ;)
I'll be there to race, but I don't think I will be super quick. The GT-R's have a massive advantage on an uphill launch, and an uphill run suits the more powerful cars. And I will be running street tyres :(
reece as alwas is quitely modest, lol, i should be entering this one, but ill be in the FSAE open wheeler, wooo, ill have my ride there to add to the line tho,
I know some of those Supra boys may have more muscle then PHD's :-), however I'm not sure we can convince them skylines came out in open wheeler configuration.
Its okay, you can double enter :blink: c'mon, support the Lines
interesting yet i still keep saying the skylines and supras are super different cars. the only thing you could compare is a gtst against one or a rwd only gtr. yet would still love to see it. take it easy, stuart (if my new engine is in can i enter)
This event is opened to everyone and is being run by SDMA, all types of cars are welcome but have to meet scrutineering guidelines i.e. safe, fire extinguisher (no plastic brackets), safe rubber/wheels (fit within guard, no wheel wobble). Club is very supportive, you can get your CAMS L2S there on the day and a daily club membership is $10 (you can do this three times and if you want to join after that your 3x$10 can be deducted from your membership).
If anyone has any questions, please let me know and I will do what I can to help out. If I don't know the answer, I'll find out for you.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
