Hey guys,
I have a HKS turbo kit with manifold and all
its a High Mount T51R
How high is this manifold compared to the 6boost?
anyone have dimensions of a 6boost rb26 high mount manifold?
I dont mind hacking the frame of the bonnet..... but i wont chop the actual bonnet skin
anyone using this manifold on a 32 GTR and made it fit?
Thanks!
https://www.sau.com.au/forums/topic/233799-hks-will-it-fit-hmmmm-how-high/
why would you need a twin t51r on a rb26?
1 high 1 low might be possible with custom manifolds, dump pipes, intake pipes, and cold pipes.
the rb26 will never flow enough for a twin t51r unless its a dedicated dyno queen
i reckon ud be better off going for twin t88's. re the space issue, u could always mount one either side of the engine.
Lag is the shizzle so just mount them in the boot with some looooooooonnnnnggggg piping. :)
hah yeah the powerband wouldn't be the best.. but i wana do twin something not right now but in the future and don't wanna go too small. Twin t04z too laggy aswell?
Like this from XSpeed.
It made 885.8hp at the wheel back in 2005. Here is the link http://www.xspeed.com.au/secret.php?area=n...mp;secret_id=85
I'm pretty sure 885 is a long way from 540hp.........
Cheers
Marty
Cheers
Marty
885.8hp is also a fair way off the potential ~1200hp those turbos are rated too. Or is this a fine example of how 'good' the HKS range of turbo's are?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
