  • Replies 146
Posted Images
i only bought it as a long motor so he will have to take out the old engine, rip the manifold and turbo etc all of it off and throw it on the new engine, put it in....
If he can beat $750 consider it his job.
cos its for my ceffy daily... too much effort to change a ceffy to manual, have to get a manual centre console and change the footbrake to a clutch and all that jazz.
just want an auto gearbox so I can pull out the old fucked one and put the new one in cheap cheap. ceffy's stock standard, and if I start modding it then it'll end up like my R32... 90% of its time spent at the workshop.
Hey everyone just a little FYI.
Phoned the pub/restaurant and they are expecting 20+ so a nice big table will be set for us :D
So on the night rock up in the outside bar at 7.30 for an 8.00pm dinner inside at the Fleet Street Restaurant!
Cheers,
Sambo
South Side Pre meet Point to be at Sunnybank Plaza around the back side of the carpark
Meet Between 6.30 and 6.50 to leave @ 7
will post pics of location
Post if you want to head over in a group from the south side so we know how many and if we have to wait for anyone
and my number is 0423612973 so call if you want to come and are going to be a little late
Thanks for organising that Damian, it's much appreciated mate :dry:
Just letting everyone know I have done a pretty much final edit of the attending list on the SAuQld Thread and have based the numbers from there on the size of our table for tomorrow night. So go on there and check it out, and please let me know if there are any changes, as I wont be making any on the day....
Clicky: http://www.sauqld.com/ipb/index.php?showtopic=1499
Reminder: If you think you may not find us, PM ME for my Mobile Number and call me on the night!11`` :(
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
