Cracking Engine For Head Gasket
Tangles
 Share
If I install Tomei Poncam Camshafts to my 03/1997 Rb25det in the Stagea, what else should I get done at the same time? On an otherwise unopened early ‘97 Rb25det engine with 100,000kms.
* Cometic intake collector gasket and Cometic intake manifold gasket, as well as a thicker head gasket like the Cometic 1.3mm.
* What bore size for the Cometic 1.3mm head gasket – 80mm, 81mm, 86mm or 87mm?
* Should I do head studs such as the ARP heavy duty cylinder head stud & bolt kit?
* How about Tomei valve spring lift kit to 8.8mm, to go with the Tomei poncams 256/256 / 8.5mm.
* What about replacing the intake / exhaust valve seats at same time?
* Should I buy valve guides for new valve seats as well?
** What else? Probably a Q45 90mm throttle body with sensor and harness.
For say $2200 all up delivered, that’s
1. Cometic intake collector gasket
2. Cometic intake manifold gasket
3. Cometic 1.3mm head gasket (what bore size?)
4. Tomei 256/256 Poncams, 8.5mm lift
5. Tomei valve spring 8.8mm lifter kit
6. ARP heavy duty cylinder head stud bolt kit
7. Chromium intake and exhaust valve seats
8. Bronzanium intake and exhaust valve guides
9. Q45 90mm throttle body with tps sensor and harness
For a basic engine freshen up pretty much, everything else is currently good for a 225kw setup using stock injectors. Lots of mods.
What am I missing, or going over board on.
Suggestions please for basic work when doing a Head gasket kit job – what to replace for what brand. Cheers
:rolleyes:
Engine:
RB25det auto awd 100,00km fully serviced & maintained
Ryco Z201 fuel filter, Ryco Z145 oil filter, Castrol Edge 0/40w engine oil
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-gruve spark plugs
Bosch 040 fuel pump with direct 400cc battery feed at 13.8volts
Aerospeed adjustable exhaust cam gear pulley wheel
Greddy remote oil filter relocation kit
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch Random Technology 617cfm metalcat
3inch cat-back exhaust system with Kakimoto Racing GTR free flow centre in/out muffler
Apexi pod filter
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Apexi 'Hybrid' front mount intercooler, tube & fin and bar & plate, with custom return air feed pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec B spec-ii dual stage Electronic Boost Controller, set to 1bar and 1.1bar
HKS heavy duty turbo actuator
Sliding Performance water/oil cooled 360degree bush bearing Hi-Flow Turbocharger
Toshi ecu remap
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphic 17inch x 7.5 rims with Hankook K104 Ventus tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Custom brake master cylinder stopper
Audio/ETC:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit
Car alarm
Dayz bodykit, twin sunroof
ok then.
got some PM advice, thanks very much Dave and Aaron
Found a really good purchase deal for the following, from a cple suppliers:
Cometic intake gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm
ARP head studs & bolts kit
Intake & Exhaust valve seals
Intake & Exhaust valve seats - Chromium
Intake & Exhaust valve guides - Bronzanium
Q45 90mm throttle body with adapter kit
Clear cam gear timing belt cover
Tomei 256/256 8.5mm poncams
Tomei oil gallery orifice
While Im doing the poncams + intake/exhaust valve seals & gaskets etc, anything else to touchup and make new????
cheers
Hey, what kind of prices have you found for the following:
Just rough prices would be a great help!
Thanks man
hey guys, what else?
(love talking to meself lol). PM'd pm-r33 above straight away, surprisd with ALL the sau engine guru's here noone has examples to add, some help etc.
keen to learn as much as possible.
got for $1100 so far:
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm Intake valve seals
EPP 6mm Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
will also get, soon for another $1100:
Tomei valve springs
I take it thats the head work parts covered. labour will be that again I take it, too.
What else while the head is off and being touched up new.
I will also upgrade the steel fuel lines too. what size is stock fuel line - outer/inner mm diameter please?
Will port out the stock exhaust manifold, unless I can find a good low-mount tig welded one for 2-300
Looking for a real good torque figure for low thru to midrange, run the slide turbo at max efficiency. 225kw would be fine for me, with big midrange and torque.
Bottom end will remain stock.
cheers
:D
You thinking about doing anything with the valves ie. 1mm oversized? Or getting some one to do a 3 angle valve job? Im tossing up on what to do to mine when i take the head off.
Other than that it looks like you pretty much have everything in the head covered.
sounds like you doing it proper, yes you will need all the gear you have listed, new gaskets everywhere, i would while the head is off put a restrictor in and do a few things thats listed in that page for oil control with rb's. might aswell do it now while everything is apart, wont cost that much at all to do and it will save your engine,
http://www.skylinesaustralia.com/forums/Oi...ui-t110680.html
 Share
