Hi Guys,
Been a long time coming so I finally got around to cleaning out the garage. All prices are negotiable and pickup in Rouse Hill, NSW, 2155 is preferable but may post at buyers expense depending on the item.
1. Genuine JDM S14a Black grill in great condition SOLD
2. Welded up diff out of a NA r32, 4.3:1 ratio, 5 bolt half shafts and in great condition - should fit r32/s13 but doesnt fit my s14 hence selling it $250 ONO
3. Standard OEM S13 Sr20 flywheel - needs machine and doesnt come with flywheel bolts $25 ONO
4. Various standard RB26 Parts including stock manifolds with heat shields, cam gears, turbo elbow, after market hks style pod filters and various water/oil lines for standard twin turbo setup $50 ONO for the lot!
5. Standard S13 rear antenna - was working fine when I pulled it out comes with everything you need $50 ONO
6. Standard S13 intake pipe in good condition $30 ONO
7. Standard S13 handbrake cables (left & right) as well as centre handbrake cable with broken adjuster bolt $50 ONO
8. R32 GTR space saver - has good tread and will work on any 5 stud nissan $30 ONO
9. Cusco R32 GTR front coilovers - 1 needs a new camber top as it has snapped off, other is fine - both worked well when removed other than the obvious $200 ONO
10. S13 Standard castor rod bracket front left (radius bracket) has been slightly bashed but definitely usable $20 ONO
11. Hybrid Dual Stage Boost Controller - was working fine when removed from car no boost creep - comes with everything needed $150 ONO
12. Standard Rb26/20 igniter - worked fine before removal $80 ONO
13. Various S13 FMIC piping - some brand new still in packaging some used $50 ONO for the lot!
14. Good condition s15 rear diff housing $50 ONO
15. 6" blaupunkt speakers - not sure what model but worked fine before I pulled them out $50 ONO
16. 60mm Autometer mechanical oil pressure gauge - in good condition, comes with 60mm cup but no sender $20 ONO
17. Standard 180sx headlights - front right is in good condition while the lens and the cover is smashed on the left, both motors work fine though $50 ONO for the pair!
18. Standard S13 headlights - front left is fine except for a broken mount whilst front right has broken mounts and a broken lense however the rest is intact $50 ONO for the pair!
19. VDO Oil Pressure, Water Temp and Oil Temp gauges - all work fine with a green backlight however I no longer have the senders. these can be sourced fairly easily and cheaply however I dont need the gauges anymore - also comes mounted in DIN slot mount$80 ONO for all 3 and the mount!
20. R32 GTR passenger side door handle in good condition $20 ONO
21. MOMO steering wheel in good condition - comes with the momo horn aswell as momo horn cover - also attached to it is a nissan boss kit which I can seperate $150 ONO for the wheel and boss kit or $50ONO for the boss kit and $120ONO for the wheel
22. Standard rear left 180sx tail light - small bit of trim on the left of the light has cracked off otherwise in good condition $20 ONO
23. Standard s13 indicator/parker front right - 1 of the clips are broken but still useable $10 ONO
24. Hybrid boost gauge in good condition with gauge hat - guage is electronic and the actual sender is water damaged so it sometimes works sometimes doesnt $50 ONO
25. C's short shifter in good condition S13/S14 SOLD
Pics:
1.
2.
Can take some if need be but looks like a normal diff
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22 & 23.
24.
25.
SOLD
All items are located in Rouse Hill, NSW, 2155 and I can be contacted here or via mobile 0403858714.
Thanks,
Brett
Edited by reaper
