Item:R34 GTR Z-TUNE BONNET
Age:3 months
Condition:Perfect
Price:Open to a reasonable offer
To Fit: (What car)R34 GTR
Contact:PM best
Comments:
Hey guys im selling my R34 GTR Z-Tune Style bonnet. This bonnet was purchased from Josh (JSAI) 3 months ago for $850.
The bonnet is in PERFECT condition. I really dont want to have to ship in interstate so hoping for a local buyer.
Any questions just PM me. The bonnet is on the car and i wont be taking if off unless i have a buyer.
Thanks
Edited by GTR32X
https://www.sau.com.au/forums/topic/234258-r34-gtr-z-tune-bonnet/
Yes it is.
If it's not, then just as much money was spent making it look and drive like one :P
Its a nugget if you ask me ....doesnt pull for shit ..
nice bonnet you shouldnt be selling it if you ask me ...
Just in case no one noticed but this is not an actual
Z-Tune bonnet, it's an aftermarket copy. :P
Thanks for your input ... he mentioned in first post it was a Z Tune style bonnet , but not the real thing and if it was the real thing you think hed be selling it that much ? Original z tune bonnets go for alot more Theyd be be worth just as much as your S15 , get a real car ....
ah bullshit... pulls the chix better then your bucket :P
you both got nothin on mine though...
swapsies???
Least you drive a skyline ehehee ....
Anywayz is this bonnet sold my sister wants to put it on her Rav 4 ... would it fit ??
I think anyone buying would know that since i have said i bought if from Josh (JSAI) and i payed $850
But i guess u didnt read what i wrote.
Next time it may be wise to read everything before posting anything champ
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
