  • Replies 60
Err not that it's really going to help much.... but anything stand out obvious wrong from these couple of photos lol. The oil feed banjo isn't sealing 100%.. i need to fix that but I don't think that would be doing it..
Hey yeah there is a gasket... It doesn't go to 0 straight away.. if i drive it it slowly climbs to a tiny bit below 0 and then doesn't go up any higher even if foot is flat.. grrrrr
that sounds like a problem, as putting ure foot down to the floor regardless where in a non turbo motor should give 0 vaccume, and on a turbo motor should give 0 vaccume then boost, i just added you on msn so i can ask you about it there instead of in a million posts
Hey yeah i can the wastegate flips open and closed without the arm attached to it just as easily as the old one.
I just went for another drive.... a big one this time... at 47% throttle (i went more than this) it's 58% airflow @ 4600rpm. It's like nothing nothing nothing then if i give it more the boost goes up to like 5psi and then when i back off the bov goes off like normal but the turbo makes a really faint spool like it does when you blow a cooler pipe so perhaps it is just leaking somewhere afterall.. Is a highflow going to make it THAT much laggier?:s Perhaps it's been bored out too much?? Doubtful as it still utilizes the same front and rear housings. I'm just waiting for someone to say that it will be different to drive with a highflow than standard but it's not that..
Which leads me to my next question... if the turbo is capable of producing even small amount of boost does that rule out that the turbo is the problem?? Or not necessarily...
*checks all hoses and piping again..*
Thanks for everyones help...
if the gate was stuck open it would go into vacuum instantly no problems and build some boost
it would just be mega laggy to build a useful amount of boost
but getting to 0 should be almost instant with gate leaking or not
it sounds like your manifold isnt pressurize, ie; your engine is atmo
this explains why you cant reach 0 vacuum
Yeah maybe you just forgot to tighten a hose clamp and its half blown off.
If its a bush bearing highflow it will be laggier again over a turbo thats BB of the same specs or a standard turbo. It won't deliver the boost as nice as a BB.
Yeah i'm gonna pull the dump pipe back off... make sure the wastegate flap is 110% closing correctly and make sure the arm is pulling it shut... when that's off also make sure the wheels are still spinning together and are tight... after that I think there's nothing more i can really do and will gladly pay a shop to fix whatever it is.
im having a brain fart but it seems like I have had this problem before. Maybe some how that turbo is out of spec?? The boost is suppose to be built up in the compressor housing and then distributed throught out the intercooler piping. Almost sounds like it may be sucking but not pushing if ya know what I mean. check the gasket on the comp housing. I think that fixed my problem before. It suxed trying to find one. or take the turbo off and get it checked by a pro. Or if ya have a freind with anouther turbo borrow it.
Good luck
Just had another look at pics.
1) Move your pressure source AWAY from your FPR.
You should NEVER tee things off the FPR signal line. You can cause pressure drops when putting things on that flow air etc.
2) Your hose clamps on the hot side of the intercooler to turbo seem to not be sitting right. Undo them, line them back up, redo them.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
