Hey everyone,
I have a bit of a problem which i cant seem to find the answer to.
I bought a damaged r33 s2, Im a panel beater my self so i have fixed the damage on my own. Now i seem to have a problem with the car running with out a problem.
The engine starts but alot of black smoke just keeps coming out from the exhaust and it cuts out as if one of the spark plugs are not working (or a coil problem). I checked all the plugs and coils and they were all fine, then after letting it run for about half an hour to see if the smoke will stop the car just turned off on its own. So I changed the spark plugs and they were burnt out on the tips. When i put new ones i thought to my self i would change the oil and oil filter at the same time. So i did all that but still the same problem.
I dont want to keep the car running for a long period because my guess is that its going to burn the plugs out again.
I asked around and a few people said its my coils, but my own thoughts to that was then why would it be blowing all that black smoke? Then another person said it can be one of my fuel sensors, saying its burning too much fuel thats why my plugs were burning out. So i thought i would ask another mechanic and this bloke said that it could be my air intake sensor.
So i would like to get some help off anyone i can if possible. Thanks.
https://www.sau.com.au/forums/topic/234688-r33-gtst-s2-rebuild/
yeah well its super rich....so i guess thats a good place to start diagnosing from... check the base timing... also check the diagnosis codes from the ecu...
Hey mate,
would you know how to check the base timing or the diagnosis of the ecu, or anywhere in sydney i can get it done? I like to play around with my car my self and feel good about working on it so yeah
im no expert but try resetting the ecu...... its cheap and quick and you'll have a result in a few mins
to reset ecu unhook the negative battery cable and turn the lights on and press the brake for a minute to drain all the power stored in the ecu so it will loose all current memory stored in it.
(dont forget to turn off lights before connecting battery up)
also does the engine shake or sound like a wrx when idle????? if so then it might also be running rich and have a spark problem that may be hard to detect,,,,,
Check the pins in the coil plug - make sure you haven't bent one out of alignment.
yes yes i agree..... it it either the ecu or something to do with the coils im racking my brain here and they most plausable still.....
and since the car is ideling like a wrx and is shakeing, whatever the prob is is making the spark f**k up.....
also check the grey clips that connect to the coils, when i had my sparks changed the idiot mechanic just connected these clips but didnt clip them in place so they just vibrated loose after a few days and made my wrx sound......
should have done it myself the first time but i thought he knew what he was doing..... lol now i know how to do it for next time
Hey guys,
ok i tried the whole reset thing. the check engine light blinked 5 slow and 5 fast. so im guessing that means things are alright. But i also had a thought because of the car accident im missing a pipe for the intercooler? so theres a pipe coming out from the engine but not connecting to the cooler because its missing? im told this can also be a reason why?
lol thats funny :D
To build boost the turbo relies on the piping to transfer it to the plenum, if there is no pipe there you cant have boost and the motor is drawing air through that pipe instead of the air filter so the air flow meter is not in the loop, frankly I dont know how it is running at all.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
