Yep, you can fit a LSD to a R33, I fitted one to my R33 GTS25 a couple of months back made. The diff I got didn't come from a skyline, not quite sure what it came off (but it was nissan). Every thing was the same except the mounts at the back of the diff, I just changed the back plate over from my old diff and that fixed the problem.
Series 1 R33 don't have vvt, not so sure with the series II, I think they might have vvt.
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-503140
On-board model R32 GTS25 (ECR32) R33 GTS25 (ER33)
R33 GTS-4 (ENR33) R34 25GT (ER34)
R34 25GT-V (ER34)
R34 GT-FOUR (ENR34)
Engine type Water cooling serial 6 cylinders * DOHC
Cylinder
Inside diameter x distance mm 86.0×71.7
Entire aerodynamic volume displacement cc 2498
Compression ratio 10.0 10.0
The highest output
PS/rpm 190PS 190/6400
[ As for Type-S 200/6400 ] 200/6000
Largest torque
Kgm/rpm 23.5/4800 26.0/4000
Fuel feeder The NISSAN EGI (ECCS) electrically controlled gasoline injection device
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-503856
ok took the cam gear covers off
on exhaust side has a 5 spoke cam gear(not adjustable)
on the inlet side has large pice of steel with a cover bolted to it
wich apears to be bolted to the centre of the cam gear (all most same size as cam gear )this i guess is the vvt
please can some one tell me if i am correct
and also if you wanted to put adjustable cam gear on can this be taken off or is it the same thing
thanks eryc
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-504173
Originally posted by eryc
kyla there is no way you could find out what your diff is off? could you?
thanks eryc
Sorry dude, I've had no luck in finding out what it was off.:)
The ratio of the diff I got was 4:3.1 ratio LSD, but knowing what I know now, I should have got a 4:1.1 ratio LSD, it would have put the speedo readings out a little bit, but the car wouldn't rev quite so high at 100km, and I would have a better top speed, I'm kickin my self now:hellpisd:
If you are getting a LSD check what type of flanges (the ones from the diff to the wheels) you have, before you go and get one. I made the mistake of not checking the first time and got the wrong one:Oops:.
I have attached a quick sketch, of the diff flanges sort of looked like the first one in my case was the wrong one (can't quite remember if it was 5 or 6 stud), the 2nd was the one that fitted my car. sorry I can't be of more help.
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-504325
"7grand clutch dump, if both wheels spin u have an lsd if only one spins u dont have an lsd."
LOL yeah that's the fun way, the more restrained and kind way is to get the car on a hoist or jack it up and turn one (rear) wheel . if the other one turns then you have a LSD.
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-504502
can anyone tell me what is going on here: i have an lsd, but if i have one wheel on grass/dirt and one on tar and i go to take off, it just spins the wheel on the grass/dirt. i would have thought the lsd would have transferred the power to the wheel with traction (the one on the tar) and i would have taken off normally with no spinning??? or is that what a vicious (sp) LSD does? what the hell is a vicious LSD while we are on the topic of them? :)
https://www.sau.com.au/forums/topic/23472-lsd-and-cam-gears/#findComment-504554
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
