Im having an arguement with a parts guy at my local nissan dealer about how many autech's were built. Does any body know the exact numbers on series 1 and 2's?
Thanks
I have no idea :3some: but i would imagine heaps of them. It would be like, how many customers ordered that version in any particular month of the production run spanning several years. There would have been more than enough built for the model to be recognised worldwide I should think. I would like to know how many really top nick examples are left? Not counting mine of course. :D
Cheers GW
https://www.sau.com.au/forums/topic/234940-autech-stageas/#findComment-4115799
Trolled through a Japanese blog site of a 260RS owner and he stated that 1700 260RS's were produced. He seems to be a pretty serious 260RS owner, so hopefully his guess is educated. Couldnt find any official numbers and no breakdown of S1 and S2s.
http://blogs.yahoo.co.jp/hachi0624/MYBLOG/yblog.html
https://www.sau.com.au/forums/topic/234940-autech-stageas/#findComment-4115970
yes it was a friend of mine that has an autech to who mailed to autech in japan and asked them how many where built and also wich colors they where made in.. so this info is directly from autech japan. i don't know how many of wich color but atleast how many of S1 and S2 that where made.
https://www.sau.com.au/forums/topic/234940-autech-stageas/#findComment-4117349
I heard that there was a nismo version of the 260rs which apparently there was only 200 made. can anyone conferm this?
https://www.sau.com.au/forums/topic/234940-autech-stageas/#findComment-4121318
I had a pic as a screen saver of a beautiful yellow Nismo Stag (think it was S1) but my dam computor destroyed it. the grill was the same style as the GTIR Pulsar job. The bonnet had two lovely vents in it, i remember that much. When i went shopping with SVI, Mick Martin I was after a Nismo or Autech. Mick never ever came back with any Nismo jobs up for auction. in fact he did not even acknowledge they existed. But.......I had a screen saver once. :D
Cheers GW :P
https://www.sau.com.au/forums/topic/234940-autech-stageas/#findComment-4121918
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
