Hey,
My car has been playing up recently, where if i leave the car to idle for a while after driving. The revs drop and it starts to splutter, with the idle moving up and down and car acting all funny.
Once i start moving and accelerating everything is fine.
Connected a ecu diagnosis tool and an error came up;
34: Knock sensor signal
I have a stock ecu, Where is the knock sensor located? How much it cost to replace? Is there a part number?
Thanks all :P
https://www.sau.com.au/forums/topic/234972-ecu-error-knock-sensor-signal/
knock sensors are located under cylinder 3 and 5, to get the rear one off the starter motor has to come off.
and pm femno bout the knock sensors he gets them for a good price
Thanks for the quick reply :3some:
Would faulty knock sensors cause the car to splutter and erratic idle on idle?
I read somewhere that the knock sensors switch the map to safemode to protect engine.
If its switching between maps, this could be causing the spluttering?
yeh i had the same problem.
couldn't be bothered fixing the sensor so did a resistor mod, basically you put a 1M ohm resistor between the knock sensor wire and ground, it fools the ecu into thinking the sensor is fine.
i can give you more details if you want, ecu pinouts etc.....
From GTR.co.uk;
right at the top of the block under where the head meets the block, 8" apart.
very difficult to get to and remove with engine in place..look under the plenum at the block as above. they have a black plug on them..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
