  • Replies 41
hey just wondering if i can have your sun visors? what color are they need both and the brackets that clip into the roof
hopefully they are grey and what condition
how much pm me?
still got the rear bumper? if its in good nick i'll take it, i never get on here though, give me a call or txt on 0415626733 and we'll sort something out
I do, bar has no major damages, just a few scratches.
Do you have a standard leather gear knob in good condition?
Only have aftermarket gear knob (in red leather).
got pics of the sunroof?
I have a pic, here it is:
Sunroof is a genuine nissan one. Opens both ways.
how much pm me?
I do have them. They are grey, but they would need a clean. (probably previous owner(s) were smokers)
You can have the pair with the brackets for $40.
Complete sunroof with all its attachments for $250.
highly intersted would you post to melbounre 3150?
wouldnt happen to have
gtr injectors
gtr fuel pump
r33 stock turbo
by any chance?
I can post, but i will need to pull the sunroof out measure and weigh it to get it priced up for freight. To do that i will need
assurance that you were certain of buying, like a deposit.
I do have gtr injectors and fuel pump, but they wont be for sale until for another month or so as i will be using them to run
the GTR (standard fuel setup till i change it when i go for a tune). Sorry dont have 33 turbo.
Items sold:
  • R/H A-pillar trim
  • Rear bar
  • Front bar & bar indicators
  • Gear stick boot and surround.
Plenty more parts i still have, so if your in need of something let me know and i may have it.
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
