im pending a big boys day with beer kegs and dress up party
but if that doesnt come to plan we'll sort something else out
what are you upto for AFL Grand final 08 ?
who is gonna win
who is gonna win norm smith
https://www.sau.com.au/forums/topic/235345-grand-final-08/#findComment-4120930
hawks are playing some decent football this season, but i'm not sure about them going as far as the grand final
dude hawks are one game away from the grand final, only collingwood or saints stand in the way..
they have thrashed collingwood by over 10 goals only few weeks back, and saints aint much chop, they would be lucky to beat the pies..
https://www.sau.com.au/forums/topic/235345-grand-final-08/#findComment-4121402
watching geelong play the hawks in the grand final @ arcadia hotel - cnr punt and toorak in sth yarra... watched it there in 07 & 06... free sausage sizzle and great atmosphere!
geelong by 44 points, y'ablett norm smith...
Edited by JMP 82
https://www.sau.com.au/forums/topic/235345-grand-final-08/#findComment-4125907
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
