If you look under the gap below the brake master cylinder, its there.
Pain in the ass to remove thou.
Its better to undo the bottom one 1st, then you pull upwards to remove 1 end, then you can take the other end off using both hands which makes it easier.
follow this tutorial and you can't go wrong. the idea of using hot water to soften the filter hoses is golden and makes it a hell of a lot easier to get the little sucker off with a lot less bleeding.
http://www.anthonymcgrath.co.uk/gtroc/fuelfilter.htm
thanks a lot for your help bro!
Cool, no probs!
is gts-t the same?
Yes it is, same location.
I have always wondered if it is worth re-locating it to a easier location.
Has anyone done this?
Its not hard too get to, its more so a pain trying to get it out.
As for relocating, ppl usually relocate the oil filter. That is a big pain to get out.
ah yeah will definitely try that next time, I almost cut the hoses in mine out of sheer frustration!
I did cut mine off :blush: Got so friggin pissed off with it, even with the hot water trick i slicked the f**kers off both ends and replaced them. Made life easy(er). Even putting the new ones on, and getting the clamps done up isnt rediculously friendly. R33 mind you, but same location.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
