If you look under the gap below the brake master cylinder, its there.
Pain in the ass to remove thou.
Its better to undo the bottom one 1st, then you pull upwards to remove 1 end, then you can take the other end off using both hands which makes it easier.
follow this tutorial and you can't go wrong. the idea of using hot water to soften the filter hoses is golden and makes it a hell of a lot easier to get the little sucker off with a lot less bleeding.
http://www.anthonymcgrath.co.uk/gtroc/fuelfilter.htm
thanks a lot for your help bro!
Cool, no probs!
is gts-t the same?
Yes it is, same location.
I have always wondered if it is worth re-locating it to a easier location.
Has anyone done this?
Its not hard too get to, its more so a pain trying to get it out.
As for relocating, ppl usually relocate the oil filter. That is a big pain to get out.
ah yeah will definitely try that next time, I almost cut the hoses in mine out of sheer frustration!
I did cut mine off :blush: Got so friggin pissed off with it, even with the hot water trick i slicked the f**kers off both ends and replaced them. Made life easy(er). Even putting the new ones on, and getting the clamps done up isnt rediculously friendly. R33 mind you, but same location.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
