If you look under the gap below the brake master cylinder, its there.
Pain in the ass to remove thou.
Its better to undo the bottom one 1st, then you pull upwards to remove 1 end, then you can take the other end off using both hands which makes it easier.
follow this tutorial and you can't go wrong. the idea of using hot water to soften the filter hoses is golden and makes it a hell of a lot easier to get the little sucker off with a lot less bleeding.
http://www.anthonymcgrath.co.uk/gtroc/fuelfilter.htm
thanks a lot for your help bro!
Cool, no probs!
is gts-t the same?
Yes it is, same location.
I have always wondered if it is worth re-locating it to a easier location.
Has anyone done this?
Its not hard too get to, its more so a pain trying to get it out.
As for relocating, ppl usually relocate the oil filter. That is a big pain to get out.
ah yeah will definitely try that next time, I almost cut the hoses in mine out of sheer frustration!
I did cut mine off :blush: Got so friggin pissed off with it, even with the hot water trick i slicked the f**kers off both ends and replaced them. Made life easy(er). Even putting the new ones on, and getting the clamps done up isnt rediculously friendly. R33 mind you, but same location.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
