I'm looking at buying the Blazer style carbon fibre bonnet from PSI parts.
Mentioned in here: http://www.skylinesaustralia.com/forums/R3...ts-t229104.html
If anyone has bought one of these, can you please upload a photo to show it off?
The pic from PSI Parts isnt the best:
Is it just a fibreglass with a layer of CF or is it full CF, probably not for that price eh?
I wouldn't worry about too tough myself...
I'm tempted to replace my current fibreglass bonnet with this one...
Bump!
Surely someone must have bought this bonnet...!
you'll have to give me some time dude, still trying to convince myself that yes I need a different bonnet after already going through the pain of installing aerocatches & getting my FG one painted...
But as soon as I get it I'll send you a picture... The war inside my mind shouldn't take too long, the 'Buy it' side usually wins. hehehe
Bump!
My 'war' was won when one of my mates accidentally backed his ute a little too far... into my car :miner: . lucky was a ute cos the hoods all he got. Anyway, ordered the blazer CF hood. Went to all the trouble of convincing the NTGov, managed to get a letter from the NT roads authority to say they're cool with it :down: (which is still in post apparently). The hood arrived this morning, will be putting it on tonight. Should be able to post pics some time this week. :P
I like it, but I wonder if there is any chance of getting the vents blocked off with removable bits so you can block the holes for when it rains... I really dislike the rain not that I have a vented bonnet... So I block them when I don't need the extra cooling...
I'd be interested to see what PSI had to offer or suggest on the subject of removable blocking plates on vented bonnets. I'm so tempted by this bonnet though looks nice... then I would also have an excuse to get more carbon bits...
ohh carbon eyelids to go with the bonnet, carbon chin or lower front spolier with canards, carbon rear wing, carbon sideskirts, come on PSI get more 33gtst carbon bits, tempt me...
the pics don't do it justice really (camera phone)
Im thinkin of getting some fenders on the car, possibly the veilside style, sprayed the cars silver, widen it up a bit, should contrast it a bit better make the bonnet appear a little smaller and the CF-black-ish a little less controlling
plus gonna do the clear indicators, get rid of the orange on side and front, should look schmick then
I was thinking about the rain, where the vents are anything electrical underneath seems covered or wrapped up.
asked a few people what they reckon, i.e. other engineers like myself, mechanics etc. they reckon I should be alright, but we do get some pretty heavy downpoors in the wet, which should start in a few weeks if that
guess I'll find out :cool:
I was actually considering one, but definitely not a fan anymore
What in these pics changed your opinion Dezz?
I'm still undecided, its the rear look i dont like, looking into the vents, and also concerned re water issues.
Without wanting to take away from Blayz's car (he likes how it looks and thats all that matters), the pics of it on his car just don't do anything for me whatsoever. I think it looks so appealing in the PSI photos because its so shaded, and the lack of front bar....one of the toughest photos (imo) of my own car is when it had the front bar and intercooler removed...plastic bags over the piping and all....
I think its just how dark it looks...same with the PSI pic
personally i like the bonnet, however it would only suit a car that is tough already.
A standard kit and car not lowered just wont cut it. Anything fat like trust/doluck/jun front and the rest to match would look awesome
hmm, I was actually looking at the do-luck or JUN kits from PSI, maybe a mix n match of the 2, but will have to save a bit for painting and fitting and delivery up here
maybe in a months time or so
have 2 make do for the time being :rofl:
So not Mean/Aggressive enough for ya?
maybe its just the stock front bar doesn't match up and takes away from the overall look. When I first saw the PSI pics, I wanted one. Now that I've seen it on Blayz's car I'm not very interested at all...Must be the lack of front bar in the PSI pic....
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
