  • 11 months later...
GUYS let me clear some things up for you!!
NO one apart from the sa police and the local councils can ENFORCE a parking fine.
if the offending paper doesnt have a council logo or sa pol logo screw it up and throw it away! answer me this where are they going to get your personal info from???? it is against the privacy act for the rego dept to give out any info on ppls
rego's. next time you get a dodgy fine take it to the person who issued it and tell them that they have interfered with private property and tell them that if the y do it again you will stick it up their bung hole!!!
https://www.sau.com.au/forums/topic/23542-park-fast/page/2/#findComment-977468
The company is owned or part owner by a tightarse called Damien Lester. His little posse of parking henchmen have started to clamp wheels if you don't pay for parking.
I used to never pay their dodgey fines that they stuck on my windscreen as they couldn't possibly enforce them. But now they will clamp your wheel and charge $100 to take it off.
The only way they can enforce fines is if you pay it, then they have your address for next time. The guy that goes around and does the fines drives a small black 2 door car that looks like a Toyota Echo, it has smart parking system decals all over it.
A bunch of dodgey pricks. I can give you the rego of his car and the rego of the guy that clamps wheels if you like.
https://www.sau.com.au/forums/topic/23542-park-fast/page/2/#findComment-978067
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
