so just installed two nismo afm's the other day at the garage and now the car won't go. set the power fc for vg30's and starts up and if you rev it immediately it'll rev fine, but will die as soon as the foot comes off the accelerator. otherwise the car is totally stock. mechanic is kinda stumped too. anyone got any ideas or similar experience? cheers
https://www.sau.com.au/forums/topic/235442-new-afms-car-wont-start/
