Hi guys,
I'm in need of some help. I have a small job for an auto trimmer. I have 2 race seats and I want small suede patches attached to the high wear areas (just like many newer race seats like my cobra evolution now come with standard). On the surface it doesn't seem hard, but I imagine it will actually be a little tricky as the race seat cover fabric is usually quite weak meaning it's not easy to stitch stuff to it, usually means some kind of stick on patch, or put stronger fabric underneath and stitch through the lot. These are very nice seats. Carbon Kevlar recaro's so the job must be done nicely.
Anyway, please reccomend anywhere you know of, or even better somewhere you've had work done. I live in inner city sydeny so somewhere close to their would be ideal. :P thanks.
Rich, a mate at works old man, has had his vintage Merc done by a group here in Syd, but can't remember the name right now. I'll find out tomorrow. He was very very happy with the work.
Not on the cheap side, but in his restoration went to the trouble of specifically sourcing the exact leather texture of the original seats for the restoration, from Germany.
barry hopkins motor trimming in artarmon... hotham pde
when i worked for honda we use to send brand new type r integra seats there to get built as they came from the factory in like 20 peices and they built them!
roger that. I will see how they turn out.
the east bear seat in my silvia is fked and I don't want this to happen to the recaros in the 7 (new covers for them are $900 for some reason, even though normal recaro covers are about $200). my cobra has nice little patches or leather or something in the high wear areas and that's what I want for the 7.
if you have a regular, recaro/velo/cobra or whatever it's probably worth buying a new genuine cover. the only reason I can't for the 7 is that those seats were specially made for mazda so recaro wont retail covers for them, you have to buy from mazda. but normal recaro fixed seat covers are quite affordable.
Here you go Rich,
this is the group my mates dad uses. Was talking to him today and they absolutely rapped with the work. He said they can at times take a bit longer, but never had an issue with quality.
http://www.prostitch.com.au/
Carlton is about 2 mins from my place
Ive been in there before, rates seemed very reasonable and the level of work is awesome (they had the shop full of customer cars when i was there)
Once i get my 32 back im going to get the seats retrimmed by those guys
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
