Hey guys,
Selling the 81.
As much as I hate it that I'm doing it i just don't have the heart in drifitng anymore. Started doing it for the wrong reasons.
The rear wheel bearings are on there way out and will be replaced before the car is sold.
WHEELS IN PICS ARE NOT COMING WITH THE CAR.
The car is a 1992 Toyota JZX81 MarkII "Yamaha Edition" (1 of 300)
The motor and all accessories were built and assembled in house at HKS Kanto, Japan
It has:
1JZGTE Motor (claimed 10,000kms since HKS build)
HKS stainless exhaust manifold
HKS 3037S turbo 480ps rated. Custom Braided Coolant Lines and Braided Oil Lines.
HKS 50mm External Waste gate
HKS 264 degree Cams
HKS 1.6mm head gasket
Custom HKS Intake Pipe
Custom HKS cooler kit
HKS 3 core radiator
HKS oil cooler kit with remote oil filter
Custom HKS catch can
HPI tourque dampener
HKS 540cc injectors
Tomei Fuel Pump
3 ½” straight through exhaust to a custom HKS Muffler With brand new Turbo to Dump pipe gasket.
screamer pipe from external wastegate
Custom HKS front pipe
HKS thermostat
Autronic SM4 Stand-alone ECU (3bar map sensor) running a custom wiring loom, mounted in the stock ECU position (out of sight) with a glove-box mounted data cable.
LS1 Coilpacks custom mounted with 8.5mm leads
R154 5 Speed Manual Gearbox
OS-Giken Twin-Plate Clutch
TRD 2-Way LSD
Rear subframe modifications (extra weld bracing + mounted closer to chassis to maintain suspension geometry)
Kei Office Coilovers (custom specs) "Tezuka Model" - Front-10kg
Tien Rear Coilovers
LARGUS sway bars front & rear (extremely thick) with pillow ball links
Strengthening rear Tie Rod's
R32 GTR Brakes (front: 4 spot alloy callipers)
HKS braided brake lines
HKS braided clutch lines
Strengthenned front Stub Axle links
Strengthenned front toe arms
Modified steering knuckles (for stupid amounts of steering lock)
All bushes replaced recently
Free Dom Boot brace
Free Dom Floor brace (monkey brace)
Free Dom Rear Pillar brace
6 Point Bolt in cage.
Tanabe Sustec Front Strut brace
Chassis Seam welding
Dart Izumi “Destructive King” front bar
Free Dom side-skirts
Hippo Sleek rear bar
Original "Yamaha Edition" rear lip/boot spoiler
Front & rear wheel arches all custom hand flared ~20mm
Free Dom single layer Carbon Fibre vented Bonnet
Clear indicators w/ blue side lamps
Dark tint rear passenger windows and rear windscreen.
Nardi Steering Wheel
Grex gear knob
Blitz Boost Guage
Greddy Gauges: Water Temp, Oil Temp, Oil Pressure, Exhaust Temp
Blitz Electronic Boost Controller – Dual SBC-R
Velo Podium Jnr Bucket Seat with custom side mount rail to suit Bride rail.
Bride “Super-low” drivers sliding seat rail
MONZA 5 point harness
some double din CD player
About the car:
The car is a special model of the JZX81 called the "MarkII Yamaha Special" one of only 300 produced from toyota. It was used as a daily driver/slider by an associate of none other than D1 driver Tsuyoshi Tezuka, who's shop Kids Heart tuned the suspension set up for drift. It has also had a small feature in a Japanese drift magazine.
The Autronic has been setup with a very safe tune by a very experienced local tuner. Simon P at Morpowa. Running BP Ultimate, the car makes 260rwkw on only 16psi (limiter set to 7500rpm) with excellent turbo response, making the 16psi @ ~3400rpm, and making 200rwkw by 4000rpm. I will find the Dyno sheet and put it up.
The car does not come with the VS-KF's or the AVS Model 5's.
The VS-KF's will be sold seperatly or for another $2300. 18 x 9.5 +15 with brand new tyres on them.
Looking for $18,000 ONO for the car. (will come with some sort of wheels on it)
The car is located in SA.
PM for real interest. NO Dreamers and also it is not Registerable or compliable. RACE/Rally import.
MSG me on: 0439 455 399 or PM here for further information or real offers.
Brenton.
* THANKS TO MIKE FOR LETTING ME USE HIS PICS FOR THIS THREAD. CHEERS AGAIN MIKE*
  • 2 months later...
Price drop to $15,500.
Car will come with 17 x 8 and 17 x 9 mesh wheels.
Don't pay attention to the stickers.
Just a mock up we did at work.
Price is neg.
Just want this thing gone
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
