Is your rear muffler straight thru? I have two mufflers - rear one has an S bend in it to help keep down noise, but have set it up so I can take off the rear one at track for less back pressure. If both are straight thru, prolly not much power advantage removing either, (but will sound heaps good) - that is if mid one is like a hot dog, apparently, if it's really big, turbulence may be removed if you take if off and there will be more power there.
yer the rear is a straight thru, i went and got a quote today on how much it would cost to replace it with a 3'' pipe and was 100 bucks, so ill most likely go thru with it, so when i take it off Zman ill let u know, not sure how much it would be for u to install it on to an existing exhaust, probs round the same as for me replacing it with a pipe...
cheers...ben.
my old system used to have a center muffler and a rear muffler, first i took of the center one cause it wasnt loud enough, that made a difference, but not enough for passangers to even notice it...
finnally i pulled of the rear muffler and replaced it with a smalish 3 inch cannon muffler, with very little baffling material (whatever its called).
Its definatly alot louder, but the problem with skylines (moreso ones with stock turbos), is that they are impossible to make loud, i got the dude at the exhaust shop to start it up with the system off and it still wasn't all that loud...
improvment in power is very minimal, maby a couple of kws?, but more than likely, you wont notice it.
I got mine done aswell, and it cost me $40 as well...$100 is a complete rip off!!!
Mine sounds sweet, a little droney between 2200rpm and about 2500 rpm, but nothing I can't deal with!
The RB series engines sound great, so in my books the louder the better. Sounds gold on full noise whilst drifting with the BOV going off all over the place.
I had the same dilemma a while ago - I had a 3" dump, 3" cat, and two straight-through 3" mufflers. I had a shop remove my centre muffler and replace it with a flaged piece of 3" pipe. Also had them make a dropped pipe, which comes out under the passenger seat and eliminates the cat too, for drags etc.
Anyway, after removing the centre muffler, my car was certainly louder and had a deeper note, but doesn't drone and has quite a nice note. With the dropped pipe on, it's not "that" loud at idle, but you can hear the turbo spool from about 1200rpm, and it sounds like a Nascar when the revs build up around 5k :P But yeah, whether it's too loud or not will depend on the muffling qualities of your remaining muffler. Mine seems to have been perfect, yours might make it too loud or too quiet. Just try it and see. Don't expect a massive power difference though.
  • 1 month later...
Interesting... I too have the 2 mufflers. My exhaust consists of:
3" Custom front/dump pipe -> 3" Cat -> 3" Nismo exhaust with a middle and rear muffler -> 4" Nismo Tip.
I'm thinking of getting this middle muffler cut out and replaced with just a 3" straight through pipe (or possibly getting it done so that i can swap between a muffler or straight through pipe, daily driving vs track/drag).
So about $40 and 30mins and it should be done eh?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
