Just finished dynoing my car, made 387rwhp on 22psi. Car started having fuel problems. Need another fuel pump to resolve it. Should make in excess of 440rwhp once i install the 2nd fuel pump. This was on BP Ultimate fuel. Tuned by Hardcore Racing. Turbo responds very well to boost increase though not enough fuel being sent to the engine. The turbo im using is a Garret GT35/40R. Not sure of the A/R sizes.
https://www.sau.com.au/forums/topic/23570-just-dynoed-my-car-387rwhp/
  • Replies 73
Thanks steve. Ive got forged pistons, rods, crank, modded plenum, bigger injec, fuel pump, microtech and so on. Only things that havent been touched is Cams and Cam gears. We think the injectors will be maxing out once we reach the 430-440rwhp mark. Though who knows when i can get the car back on the dyno with another fuel pump in it.
I know. I want to do the cams though... all depends on the $$$ flow. It drives awersome. 1st to 3rd wheel spinning 275's. Pretty scary. I pick up the car tomorrow morning and thats when i will get the dyno sheets. But i have no idea on how i will post them. It just got off the dyno an hour and a half ago.
The cars a daily driver. And believe me i have a grin from ear to ear. Im happy with fuel consumption becuase majority of the time im off boost and i can control my right foot. Though when i start pushing it abit i do watch the fuel gage go down. Im building the car cos i love the rush, i love power and being nailed to the seat. It may not be the quickest Skyline on the St or car but F**k its quick.
I remember you saying how you thought your garrett turbo was better then a Trust td06 turbo a while back
Its nice to see the power your making now as I made 303rwkw at 16psi on a remapped factory ecu running very rich, we have since had a power fc fitted and tuned at 20psi so I'll be very interested to see our comparisions once I've picked the car up and have the dyno sheey to post
I've really got to stop reading these threads. I am hanging out for mine to finish.
Any one remember that Nissan Patrol TV Advert.????
Hey buster, how you doing. I never said my turbo was better then a Trust TD06. Though it is cheaper to buy then a Trust turbo. By the way, the figures you are quoting.. is this from your black Skyline. The one i looked at?? My car would of made 303kw easy. Just a minor fuel prob. No hassles for me.
But it does give you a rough guide.. 22psi is pretty far away from 13psi even if the dyno's are reading different.
The day doesn't affect it to much depending on what mode you run the dyno in. i.e I made 115rwkw on a cold day when dead stock then on a 34degree day I made 113rwkw.
Tuner is a big aspect of the tune though.
lol.. I remember thinking wow 300rwhp... now its more like oh yer.. 350-400rwhp.. big deal... hehe :O
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
