Was giving my car a bit of a squirt the other night and noticed something interesting. As my rpm gets to around 6000 the boost starts increasing and continues to do so until 7500 and i change gear. It's ok at the moment because i've only got it set to 12 psi, and it climbs to about 15 by the time i shift, but i do want to fix it because i plan to run 14 or 15 constantly.
I can think of 2 possible causes, and was wondering if anyone can rule out one or the other.
Possible cause #1:
When i fitted my JJR split dump pipe, i didn't check if the divider was effecting the wastegate's ability to open fully. It could be stopping it from reaching it's full open position, and thus my boost begins to increase at high rpm.
Possible cause #2:
A bit of high school physics here... When i put the rb25 turbo on, i had to weld in a nipple to feed pressure to the wastegate actuator (as the rb25 turbo doesn't have it on the turbo like a rb20 turbo).. I've welded it into the pipe just after the turbo, but on a little peice off to the side of the pipe (not in the direct flow of air) .. It could be that at high rpm, the fast moving air going past the section with the nipple on it is causing a pressure drop in that area. Same principle as an aircraft wing.
(sorry if i didn't explain the nipple position very well .. i can post a picture later.)
How can i test if the wastegate is able to open fully?
Should i move the nipple regardless?
https://www.sau.com.au/forums/topic/236206-high-rpm-boost-increase/
what boost controller you running?
i would think option 1 is more likely, i doubt there would be a pressure drop big enough to affect the actuator. If you have a compressor handy, just pump some air on to vac line going to the turbo and watch the arm move, see if it is hitting at all.
only noticed it happening in 3rd and 4th (coz the time between 6000 and 7500 is so small in 1st and 2nd)
just using a turbotech manual controller, but if the moving air is causing a pressure drop of 1 or 2 psi in that area, it would cause the actual boost to increase by that amount.
how can i tell if the wastegate is opening 90% or 100%?
i would try and hear it and see if its hitting,
or
measure the amount of movement it has with the dump on, then take the dump off and measure again
If you think there actually is a pressure drop, take a vac line from the manifold and connect it to the actuator, take it for a quick spin and see if it creeps again
I'd say it's the jjr split dump. Lots of threads have been popping up involving those dumps with your same probs. I even had the same prob on my split turned atmo screamer pipe, chopped off the tiny screamer pipe and put a 2inch one and it's grand :)
turns out the different turbo / exhaust combo was causing the actuator to hit the support for the heat shield.. took to the heat shield with an angle grinder and it's all good now.. wastegate was probably opening about 80% .. full range now. yay..
dial it up to 14 or 15 tomorrow, then gettin it dyno tuned monday.
i had a 25 turbo and a jjr split dump/front with a 20 actuator.
my boost went straight to 9psi. then steadily creeped to 14.5psi @ 7000rpm
changed to a non split dump/front and now boost goes straight to 10 and slowly creeps to 12psi.
what exactly did you grind off?
There's like a plate which does a half loop around the dump pipe.. this plate is there to provide the 2 top points to screw in the original heat shield.
When the wastegate actuator was trying to fully open, it would hit the plate and not be able to reach the fully open position.
To test if yours is doing this, take off the heat shield and remove the circlip that holds the actuator's arm onto the wastegate control. You should then be able to move the little control peice of the wastegate.. turn it around with your hand and see if it hits the plate.
hard to describe.. if you like i can take some photos when i get home from work.
Edited by Wogan
I dont have a heat shield on bro. :cool:
From what i remember of my engine bay, there is plenty of clearance for the actuator piston/arm to move freely.
And as i said, boost was 9-14.5psi, now its 10-12psi. So it isnt 100% fixed. but 12psi is what i want
Edited by Tezzah
hmm.. that's an interesting situation you have there then...
Not sure i can be much assistance then.. all i know is that in my case, the cause of the additional boost was the wastegate not opening fully.
Best of luck Tezzah!
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
