what for, i got an alarm now :down: they never state (when your signing up) that claims = fail if you dont have an aus standard alarm and immobiliser.
yeh they never mentioned it to me either but when i gave the papers a good looking over it says it in like size 10 font in the corner sumwhere, so i got one the next day lol
  • Replies 51
Posted Images
i'll keep an eye out mate, always easy to spot skylines on the road, hope you find them and hurt them painfully!
keep an eye out for what it was found burnt out
what for, i got an alarm now :) they never state (when your signing up) that claims = fail if you dont have an aus standard alarm and immobiliser.
they dont tell you that because you would get the insurance if your knew
sorry to hear of your loss
Dunno man, both Justcar and Shannons made sure I had an Aus alarm. There was one fitted when I bought the car but it was utter shite so I got Adelaide Pro Sound to wire me up a new one. Been awesome ever since (and the turbotimer/remote turnoff feature is uber)
-D
hey so last night i went and saw the car i was debating wether to or not due to my massive attachment to it and didnt know if id be an emotinal wreck... but i went and saw it so it didnt get to this "carport" till just after 6 pm last night apparently it was getting chased after all night. they jacked the car up and took the mags and then set the interior on fire. the motor looks fine and so does the shell to my surprise i was expecting the whole thing to be burnt to a crisp!! they had ripped off the for sale stickers and left all their munchy wrappers all in the car. the fireys came to put it out and its been fingerprinted still hard to get my head around but hey. thanks rhys for your comments its totally devastating to have this happen.
Alarm has to be Australian Standard aswell - they'll check by taking a squiz at the alarm remote and can tell from that! :happy:
just on a diffrent note how can u find out if your current alarm is aust approved ? you may have brought a car with a alarm in it all ready . you would not know if its approved or not .
Was going to ask the same question!!
all my remote has written on it is tonkins i cant find out what model it is as i cant find where they hid the bloody thing lol exept for the siren under the hood . all i know is it goes off pretty easy and is as loud as hell .
I'm with Just Cars, and they said the Viper alarm is fine, even though it's not Australian Standard.
Did they verbally say that, or put it in writing?
Verbal dont mean jack, even if you were to write it down, date+time stamp it, and have a witness with you.
Any easy way to get something in writing, is to email it to them. Make sure their email has their full name+position on it too.
Just verbal!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
