Read the post by rips a few up. I wouldn't worry at all about using rb25 head studs.
Yeah i seen that , 8 second defs made me feel better but usually 8 seconds could be rebuilt motors after so many runs etc..
Ok this is excellent feed back... This makes me feel alot better about it.
Did you guys torque the bolts to the recommended setting or go a lil extra?
From memory it was like 85
Dont go more torque than in the manual.
Any more may distort the deck of the block which you dont want.
Also remember the RB30 block is thinner and weaker around the bolt holes, the block material is also a lot softer than studs, so removing thread to fit a bigger stud only weakens your blocks deck area for the sake of adding more bolt strength which is already more than adequate.
The deck will distort more than the bolts can stretch.
We are using RB25 studs on our 600KW build.....any give will be from the block deck distorting to hold the studs/head down, not weak studs stretching......
Go back to page 1, 2 well known builders who do this for a reason, if there was a gain going bigger, they would have been doing it.
Edited by GTRPSI
This is what was tripping me out abit too, no tuner i spoke to said they have ever encountered the casting mark where the idler goes... they said they are all flat .
The casting gets in the way of mine... it wasnt a big issue we made it flat but dno if that helps u guys distinguish what type of block it is.
there is at least one thread on here with a block with the same issue, I think he was in the usa, cos if you are in oz the obvious thing to do would have been get another block.
There are some posts (i think they may have been here) on the web where people have built washer type spacers of fabricated some steel to compensate for the block finish as in the pics above and it worked just fine.
sall good we were able to make it flat and fabricate a solid spacer for it . :)
that's the proper way to do it.
as alrady said, you can get a washer style pacer made, but being timing belt, youd want to be 100% perpendicular.
Couldn't you get sleeves made up to slip into the head bolt holes so you can just use rb25 ones?
You don't need sleeves. It's the dowels that align the head to the block, not the bolts or studs.
  • 4 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
