hey guys,,, so the story goes back in 2006 i was the cause of an accident. i was fined and had 3 demerit points taken off me (im a p plater btw) and since then ive been pretty well behaved behind the wheel. wont punch orange lights speeind etc etc as a chef i just can not loose my liscense. over the last 2 yrs its became habit to cheak my speedo every 5 meters i drive pretty much. and lastnight coming home was noi different sitting dead on 60. my gps saying 61. and i got flashed at a red light camera. it wasnot a red light and i know that i was not speeding 100%. where do i stand? i havnt got the letter in the mail yet but im pretty off the whole thing. cheers.
https://www.sau.com.au/forums/topic/236555-speeding-fine/
  • Replies 93
you will be srprised mate, ive been flashed many times, i drive around 3-4 hrs a day and have been flahed a few times
even though i wasnt speeding and never seen anything from it...
i just think it maybe test flashes?
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4139960
... or faulty equipment, or a bird flying past the radar or something or somesuch.
dont sweat it til you get the fine in the mail, then dispute it. simple.
(bahaha, didnt bother refreshing, ruby beaqt me to it ;))
Edited by scandyflick
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4139979
Same here, was also "test flashed" about 2 weeks before i got off my p's with only 1 point left and was freaking out. Was doing about 54ish in a 50 zone but nothing came of it so i assumed i wasn't over or i was just on the "flash" limit.
But yeah... always request a pic. At least then you have an "in action" photo of your car ;)
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4139983
normally they keep the photo as its government property and nowadays they dont make a hard copy of it they bring out a laptop and show you
yeah ive been flashed before too and thought 'What The'
i think its to put the fear of SAPOL into you ;)
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4140004
man, that just takes the fun out of tearing past speed cameras... ;)
(im jokin kids.)
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4140010
where was it? the police do have a speed camera testing section who often calibrate and test the speed cameras.
Last night i sat at BP on west terrace with some mates having subway, and they were doing some work on the red light camera at that intersection. I think i saw the camera go off about 30-40 times for the 15 minutes i was there.
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4140333
i wouldnt be surprised.
theyre brutally bright when its dark and youre heading the opposite direction, i really wouldnt be shocked if someone had hit something after being flashed.
https://www.sau.com.au/forums/topic/236555-speeding-fine/#findComment-4140872
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
