I dont know how i will go with this but....
I need a heavily modified ride (for 2 people) to pick up and drop off over the east side.
The trip will be no longer than 10km and you get to go through twisties up Mount Dandenong.
CBF hiring a limo because its old school.
Anyone know of a limo company that specializes in using imports? or anybody on here with a modified import want to make some dosh for driving just two people from bayswater area up to near olinda?
They will be compensated for the 15 mins it takes. i will pay cash.
cheers
https://www.sau.com.au/forums/topic/236727-import-needed/
lol its for an anniversary. long story but will explain to the person who can help out.
i dont care about fast, i just want need a car to do a pickup and drop off. only 13 km between the pickup and drop off.
https://www.sau.com.au/forums/topic/236727-import-needed/#findComment-4143301
Nothing thing fancy Series 1.5 Silver 1995 GTS25-T no mods except for aftermarket blow off
Can use as last resort, but would like to meet the passengers before the day, live a bit far so just throwing it in as a last resort cause I would like someone to help out if I was in your situation
https://www.sau.com.au/forums/topic/236727-import-needed/#findComment-4143774
yeah r34 gtr would be the go i think. my stagea has the classy leather and wood grain along with the privacy window tint much like a limo.... but in the end its still a family wagon, he's not going to woo his lady friend in that haha
Edited by RBPOWA
https://www.sau.com.au/forums/topic/236727-import-needed/#findComment-4144024
cheers
Hehehe - Sounds like a "Transporter" job.
I got an R34 sedan - but its pretty much stock - PM me if your interested.
https://www.sau.com.au/forums/topic/236727-import-needed/#findComment-4147357
Mine isn't heavily modified but I might be able to depending on when you need it.
R33 GTST. Picture is the sig in my posts. Rims, zorst, not much else. Dont mind giving it a clean beforehand as well.
https://www.sau.com.au/forums/topic/236727-import-needed/#findComment-4149639
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
