Hey guys.. we down or what?
Date : 19th October 2008 (9am to 4pm)
Place : Wigley Reserve, Glenelg
Cost : $20/car
Website
http://www.sportingcarclubsa.org.au/Default.aspx?tabid=79
Because of the venue, places are limited this year and pre-registration is essential.
Looks like they're going the All Japan Day route and not promoting club displays (bit of a shame really) but doesn't stop us from all entering.
https://www.sau.com.au/forums/topic/236730-small-car-sunday-2008-sun-19th-oct/
  • Replies 260
Just gave them a call, you can display as a club if you all rock up on time, but no banners etc can be staked into the ground. Basically there wont be much room between cars, so clubs will have to rock up together to be together. Payment must be made on the day, but pre-registration is essential, the reserve holds 250 cars. 3 trophies only, 1st 2nd and 3rd, and a peoples choice award will be given.
I think the whole scene has changed - used to be the big adelaide clubs that'd enter scs (peaks, iblis, plat, etc) but they're now almost all gone. SCS has always been about the clubs.. and doing the friendly inter-club thing.
Anywayz.. i've got my form in. We should organise a pre-meet before we enter I think.
Meet at the SAU clubrooms = Vilis on friday nights ;)
Geez 1 month notice aint too long! I've found SCS in previous years to pretty good and laid back compared with autosalon - more cars, more car clubs, cheaper entry fees for spectators and those entering their cars... more focused towards car clubs coming together I guess?
But yeah, I'm in - car just came out of the panel beaters today looking schmicker than ever :P
So, lets gather a list of entrants up:
- Howie
- Damo_R34
- typevu
Last year was pretty good, our display looked pretty good and it was a fun day just hangin out with everyone. We were lucky we werent next to the sprinklers when they went off - that was bad, but funny. Poor people whos boots and tents etc got soaked.
Yeh SCS isnt like it use to be years ago, but would still be good to see a display...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
