I’m looking for ideas / experiences with the idler / tensioner setup on the 30DET.
Having checked out the guide, I’ll be going with one high, one low. I do see clear value in moving the position of the bearings.
The question is whether there is any net benefit in using 2 x tensioners – other than saving a few $$ on the difference on the higher priced idler? It appears that either setup works quite ok, so is there any consensus on what is “best”? And does the use of two tensioners require a different spec timing belt.
Timing belt wise, I’ll be using either a Dayco 94407, or Bosch T866 which are both listed as 152 teeth x 25mm wide.
https://www.sau.com.au/forums/topic/236787-idler-tensioner/
Hey Dale,
On my setup i'm using one of each, don't know what benefits, etc there are, but that's how my mechanic wanted it. I am also using the Dayco belt. I recommend you move the lower tensioner position an extra 2mm to the right (from centre) to what is stated in the document, as even with the tensioner on the loose setting the belt was pretty tight, this was done on the second build of my engine.
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4143986
Hey Dale,
my engine is exact same setup, one tensioner and one idler, the belt is also pretty damn tight to get on even with tensioner at the loose setting so i agree on the tensioner move to the right abit to give it a fraction of slack.
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4143994
Nearly caught myself out there with moving the tensioner mounting point. You're obviously referring to moving it further towards the right side of the car, or further left of centre as you look at the front of the block? ie the "other" right? :) Makes sense and an easy adjustment to make before drilling/tapping - thanks fellas.
Clearly the suggested use of two tensioners in the guide is another approach to address the issue of getting enough belt slack to make installation easier. So are there many people who've done this, and was sourcing a second spring for the additional tensioner difficult? It's all minor detail stuff, but interested to find out anyway.
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4144235
Its the top tensioner you want to move a fraction from the pdf, about 1-2,, to the left. Im using 2 tensioners, as it allows me to make the cam timing marks align exactly with the differences in deck height of a machined block/head, and thinner or thicker headgasket. ie if you tighten the bottom tensioner, and loosen the top, it advances the cam timing of both cams.
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4144268
fwiw ill be running two tensioners, one high one low.
Good information, thanks both of you.
So what is the source/spec of the spring to use with the additional tensioner? Or are you going without?
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4144564
  • 1 month later...
Start with a full taper tap, and put some grease in the flutes to lubricate your progress. Don't force things overly, and be prepared to back your tap out to make it easier. Remember you are cutting a thread, not just winding the tap in to an existing thread. Also keep an eye on things to make sure your tap is running in plumb.
Not that hard.
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4211986
  • 1 month later...
I am about to be doing this to my RB30 block.. However I have a question. looking from the front of the engine the stock tensioner position on the RB30 is to the left of the engine/belt.. can I keep this position or do I need to move it to the right side? I was planning on putting the other tension above the water pump and on the right side. The reason I ask is the pics I have seen show the exact opposite set-up so I wondered if there was a particular reason for this?
If I have to move the lower tensioner over there is a hole for the stud.. but no flat area around it to lock it up against. wil I need to weld and machine the block back or something? also where do you put the small stud for the tensioner spring or do you do away with that?
Thanks
Lee
https://www.sau.com.au/forums/topic/236787-idler-tensioner/#findComment-4316146
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
