Adr Or Cam Approved Braided Hoses & Qfm Pads
  • Replies 41
Hi Mark,
I'm after your package #2 deal. Set of ADR approved braided lines and K500 pads front and rear. I've got a 32GTS-t with standard rear brakes but i got R33 brakes for the front which i'm looking at fitting soon. I'm not sure but guessing R32 and R33 brake lines the same length/fittings?
Cheers
Hi Mark,
Cheers
Hey mate,
The 32 and 33 hoses are different. You will need 32 gtst hoses with 33 gtst fittings.
Just send me a PM when you're ready to order.
Cheers
Mark
Just got my lines made up today. Goran was awesome to deal with!
Apologies for not going through yourself, I required to head down there as I needed to customise my lines according to the current set up I had with the hard lines and brackets I had on the calipers (R33 GTS-t calipers on RPS13). The lines were made on the spot whilst I was there :nyaanyaa:
Thanks for the hook ups Mark.
Cheers,
Andy
^ Yeah but Goran won't be. From what he told me, he'll be in only between 11am to 2pm Mon to Fri. He's the man to look for when it comes to the lines...
Also, I used up the last of the braided lines yesterday lol. I needed to go black covered rears and clear covered fronts :)
Might need to wait until the new year champ. Give Goran a call to arrange something.
Cheers,
Andy
  • 4 weeks later...
Been searching & can't find what I'm after so......
How do the K500's compare to EBC Greenstuff for cold & hot stopping ( street use only ) ?
Cheers.
Cheers.
http://www.skylinesaustralia.com/forums/Br...gs-t169972.html
Apologies for not going through yourself, I required to head down there as I needed to customise my lines according to the current set up I had with the hard lines and brackets I had on the calipers (R33 GTS-t calipers on RPS13). The lines were made on the spot whilst I was there :)
Cheers,
Andy
Goran's great like that! I took photos and measured my ones up on my R34 sedan to be used with R33 brakes, just done the measurements and everything and he had them sent to me so quickly! Very helpful and easy to deal with too :)
Any front pads available for 1998 Stagea Series 2?
These are different to Series 1.
I am in Melbourne if that helps - can they make custom pads?
http://www.skylinesaustralia.com/forums/St...kes-t82083.html
Thanks.
Thanks.
PM Sent
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
