I have a r33 gts-t but with a rb26/30 engine in it, she has full forged internals - Arias pistons, Arias Rods, Full Tomei Gasket kit, upgraded cams...lets just say she is a weapon but he thing is its got standard turbos on it, im wondering if anyone out there could tell me whether to go back to a single turbo formation or keep the twin setup, also what type of turbos to use...im looking for big hp out of this engine as its built for it...
thanks every1 :)
https://www.sau.com.au/forums/topic/237148-rb2630/
Been looking at this lately aswell, as im leaning towards a home built RB26/30 instead of a straight Rb26
Lost of guys in the UK have done alot of research and testing on turbos for 3.0l RBs (one dude has tried like 5 different turbo setups...cash to burn) and there is loads of info on both the SAU RB30 dyno sticky and on the UK GTR forum.
But from what ive gathered in my research lately, ill give you sorta both ends of the power spectrums for both setups...
Most of the local boys seem to like using singles, with a GT30R as a minimum (350+rwkw) and serious cars use hardware like GT42Rs and T51Rs (600+rwkw).
But twins could still be an option. Garrett -5s are probably the minimum and i think would spool nice and quickly (350+rwkw) and on the other end the scale a highmount pair of Garrett GT3071s would make for a wild ride (600+rwkw).
You need to set some firm goals, both for power and responsiveness. What will the car be used for etc. And then use all the resources to work out what the best setup will be for you.
Hope that gets you started
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149100
A few people on here run GT3076R turbos in the .82 AR rears they are making good boost around 3000rpm and top out at 300-320kw, then there is the GT3582R, in .82 AR rear this turbo is capable of ~350-370kw and is on good boost levels around 3500rpm and with the 1.06 AR rear is good for a bit over 400kw with good boost levels around the 4000rpm mark. (by good boost levels i mean 1 bar or more)
i personally haven't looked into the twin setups much so cant really comment on them but the Veilside R32 drag car runs twin GT3582R's so if 1400hp is your goal that's a possibility :banana:
Edited by TiTAN
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149157
if your sticking with the stock manifolds get twin
else single high mount
as said above set some power/response/cars purpose goals
twin you need 2 of everything so it will cost more, unless you get soemthing like a GT-RS twin setup on stock manifolds
then you can utilise most of the existing hardware
high mount single ftw.....
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149256
Turbonetics GTK series gets my vote... either the 650 / 800. Just came out from a build with one of these and we are most impressed with the results. Compared to the Garrett items; cheaper, better build quality, and better performance IMO.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149481
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
Since the day i drove my 3L ive wanted to have a go of a built 2630 with something like r34 n1's or 2530's just to see how much fun that can be in the hills
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4159895
I don't think it's going to be a very fair comment from me as I do run an auto transmission with a high-stall convertor. Car is still at the tuners (awaiting new flex plate) so all I can go off is the initial graphs.
14 psi is reached at 4,200rpm...
I'll post up more info next week after the tuning is finished, as I believe this result can be improved by tweaking the E-01, so far only the F-CON has been tuned and not the EBC.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169086
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
A mate has these on his 30, makes 540whp @ 1.3bar!
I've got a GT35R w/ .82 housing to go on my 30 :cool:
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169770
hurry up and get it on there already bubba :)
Soon! plenum should be ready very shortly, spoke to the fabricator on Tuesday, all the prep work was done and he was about to start welding!
Got a graph for the 2540's?
What else is done to it - cams, headwork etc?
I bet its a fkn rocket
No graph handy, it's a 25t head (no porting or anything), 272 cams I think, greddy plenum, q45 t/b.. and it's in a 4wd platform.. yes, it's a fkn rocket :D
I have a clip of it's first night out.. pm me if you want to check it out ;)
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172400
Not sure what to do with my exhaust.. was thinking 3" dump off the turbo, then join the gate pipe in where the front pump turns horizontal and flare to 3.5".. or should I be going bigger straight off the turbo?
Edited by bubba
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172480
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
