Some great shots in there
Whats with the wheel/rim on the green stuff? Pics of the car it came off?
I think it came off a v8 car. Not to sure if i took the pic of that car.
I gotta go thru all my photos again!! If i do find it, i will let you know!!
Wow!!
Abosilutely awesome shots there Sid!
Done well mate!
Oh, Dan is the driver of the sureflo 300zx - ex SAU NSW President :)
Cheers dude :) Glad you like the pics.
hopefully my next time out there, i will get some panning shots..
Ah the blue 300zx.. Sounded nice too!! Is he still on these forums?
Dan - if you do read this and want bigger size shots just pm me :thumbsup:
nice pics mate. sorry I missed the event. I love watching the drift at oran park. makes for a much better drift track than eastern creek for spectating imo.
Great shots sid. ill post my mates up when he gives me a copy. The wheel came off mingay's vz commodore, Front left through the dip into the last corner. Did u get any shots of the car screpis was driving when he belted the wall at the end of the sunday during the expression session
Um which car was that? lol
I left at 2.30pm, so if anything exciting happened after that time i didn't capture anything sorry.
However theres a member on ns.com who took a pic of some car hitting the sidewalls?
I wil try and find a link.
  • 1 month later...
Hi All,
Sid, Awesome pics mate, especially for your first time out. Very big well done. And Chris, thanks for remembering me... seems I have been away for a while... lol.
Sid I'll pm you re some bigger res shots, as I know the Drift Z's owner and sponsers will like to get hold of them and thank you for the offer. VERY much appreciated.
Keep the pics coming all and,
Stay Sidewayz Kidz,
Dan.
(Ex SAU Pres, lol)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
