Where To Buy/what To Do: Dash Lights, Towbar
Hey guys,
Does anyone know where can I buy a replacement globe for the light in the climate control panel for my R33? It's the tiny little globe with a flat backed plastic retainer that you turn out with a screwdriver, it has the globes legs wrapped around it. As it's not a commodore or falcon part, Supercheap don't stock them, so does anyone know if a Nissan dealer would carry them or whether anywhere else sells them? I could always try converting the little plastic container to hold an LED but wouldn't mind just getting a replacement straight away.
Also, I'm going to need a towbar soon for towing a bike trailer, so what have you guys with R33 Coupe's done about towbars? I've read some of the technical forums, but I'm not sure if the 180/200sx ones will fit, or whether I should just get a custom one made up. Any help or hints there would be appreciated!
Cheers!
Hey guys,
Do yrself a favour and buy a set of LED's from 666DAN... ive had a set of blue ones for 6 months and theyre great. Perfect excuse for some interior bling! (Search forums for dan's led's)
-D
T-10 globes are too big, I've got a set of them here that I used in my old car.
My trusty digital verniers have just informed me that the actual globe size is the T-5 size, however it's not the regular T-5 wedge or blade shape that you get at Supercheap, these globes live in a little plastic insert (and no, it's not just a wedge/blade globe stuck in there) which looks to me like the one unit (until you break the wires and pull the globe out like I did >_>)
So they're a T-5 size, just not the standard connector. I'll check out that eBay store.
Any ideas about the towbar anyone?
go see a towbar specialist my understanding is R33's are only a half chasiss car and you will need proper purpose built stuff anyone confirm?
as for the ebay store you wont find the globes your after but i know he does the kit so just message him and tell him what your after
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
