Hello,
Ive purchased a GT2530 turbo from yahoo auction which was listed for Skyline RB's.
It arrived yesterday and noticed that the exhaust housing was nothing similar to rb20/rb25...
I was wondering if anyone could identify the exhaust housing for the turbo so I can sell it.
If anyone wants it, you can have it for $900ono.
The little Garrett plate has seemed to be snapped off the turbo, so cant identify it with any model numbers..
It has a T3 flange, just the exhaust housing doesnt match up with standard rb20/rb25 dump pipe..
Hopefully someone can recognise it or it will become an expensive paper-weight :P
Cheers
Patrick
https://www.sau.com.au/forums/topic/237440-what-exhaust-housing-is-this/
it's an early hks turbo (either 2530 or 2535) that used to be sold with a cast dump to suit an rb front pipe.
Very early 2530's came out this way, as did the old t3g's. I have seen the dumps first hand.
The outlet looks very similar to an IW t2 turbo so all is not necessarily lost. Just a bit more custom work....
Interesting that it has a "Garrett" housing on it - and you mentioned 0.67 A/R . Can you double check it to be absolutely certain it doesn't say 64 or 0.64 because Garretts usual T25/28 flanged GT28 housings are normally 0.64 A/R ratio .
Me wonders if the later HKS branded turbine housings were also 0.67 A/R because that would explain partly why some HKS spec turbos ie GT2530/GT2535/GTRS(GT2871R 52T) make slightly more power than even a very close spec Garrett market turbocharger .
I remember seeing a bush bearing turbo at Turbologic some years ago that used I think the same turbine and it had a "T3" flanged Garrett housing on it . Have to look closer into this as it may have the same turbine housing as that early HKS one in your pics .
If this is the case we may have stumbled upon the critical thing that allows us to mount GT28BB Garrett marketed turbos on RB engines and save a few bucks over expensive HKS units .
If there are any part numbers cast into that turbine housing of yours can you let me know and I'll chase it up .
Cheers A .
Hey Rekin, as i said on NS.com im using the exact same turbo currently on my RB20, i bought it as a HKS T3G turbo with the stock cast dump pipe to suit it, bolted straight up to my RB20 and is making some very decent power on my engine with minimal lag for a RB20. Mine still has the ID plate on the turbo, i can get the numbers off it tonight if that will help anyone?
Cheers A .
Hey, very interesting to read, thanks for the info.
I found some numbers, let us know if they mean anything :mellow:
The numbers on the side say something like;
M3
67
H4
558
Hey, Would you happen to have a part/model number for the dump pipe?
If i can get a number, i could probably chase one up through HKS etc
Thanks :rant:
Something I forgot to mention was that generally Ball Bearing type "GT28" style turbine housings have six holes and bolts to clamp the crab plates onto the turbos center section (bearing housing) .
From what I can see yours has four and that sometimes means it's of a bush bearing type turbocharger , they possibly interchange so that could be one answer .
I'll have to look into the old TA/TB34 series turbos to see if they used that housing .
A .
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
