Sooo... I've been mucking around with my iPhone and been writing a couple of apps (one of them should hopefully show up in the iPhone store if its approved).
But I've been thinking... it'd be great to have a iPhone Consult port application. Basically I'm hoping to get a group of you guys who might have some background in programming, and interfacing with the Nissan consult system. There's two ways we can go... either legit and sell the application thru Apple, or go renegade and distro it for hacked iPhones. I'm personally in favour of the latter, but then again, there's always that lure of money and fame :cool:
Before we get carried away, a list of goals for the app:
Interface with the CONSULT port... easiest way would be to use a serial channel:
http://devdot.wikispaces.com/Iphone+Serial+Port+Tutorial
This kinda means that the application has to run on a jailbroken iphone though
Although I did come across this... a iSkin TX/RX (http://www.iskin.com/ceruleantx/) which is an official product that allows you to send audio over bluetooth... I'm not sure if its adaptable to serial communication, but with a name like TX/RX its quite interesting.
Has to show pretty gauges (something a bit nicer than Datascan does). Has to show data in realtime. This data can be in graph plots or in gauge form.
Has to be able to give the user a more human language translation of error codes, and switches available.
Has to be able to log the inputs received along with time and location. This would be a killer function for both tuning and datalogging on track days etc.
Has to make full use of the iPhone's accelerometer and pseudo-GPS. One for mapping G-forces etc, and the other for logging geolocation.
If you guys look at the app "Rev" that just got launched a little while back, they kind of do something similar with the OBDII port using a bluetooth signal. However they don't make use of the accelerometer, and they don't do data logging.
Anyways... I'm just putting this post up, so that if anyone who reads this forum is keen on the idea and can actually contribute, then they can make themselves heard. I'll be doing some more planning in the days to come, and probably try and put together a specification of some sort to work through. If you guys have any ideas, please post them up.
https://www.sau.com.au/forums/topic/238030-iphone-consult-software/
well the first hurdle is the physical stuff. i wouldnt toy with bluetooth if the iphone has an actual serial port (which is great if it does, as the tendancy these days is to just have mini-usb and thats all which blows)
if the iphone is 3v serial input then the consult cable for it would be even simpler than a normal consult cable as you just make it use iphones 3.3v as power supply, and you lose the rs232 level converter and 5v vreg
maybe drop the 10k down to 6.8k due to change in voltage from 5v to 3.3v (keep current the same).
once you can verify the serial comms (e.g send 0xff 0xff 0xff and get back 0x10) then at least we know its do-able. no having an iphone myself means i cant help much in that regard
haha mate I was just reading over some of your posts to put together a consult cable the other day. The serial input is actually a hack, using the proprietary iphone port, and some base level interaction with the darwin based unix platform running on the iphone to get a TX and RX signal. Not too sure on the voltages, I'm waiting for my iphone port breakout circuit from sparkfun to arrive so I can toy with it some more.
n95 is symbian not windows. if it was windows it could use ecutalk. but then again it doesnt even have physical serial port, only mini-usb i think? so its fairly useless trying to do anything for it unfortunately
True that, the bluetooth connectivity on the iPhone is shocking, ive done extensive training on the iPhone itself working at a Telco and working in a support role, so i need to know the iPhone inside and out ( not literally inside, if i ripped one apart i'd die :D )
The Physical port would be the way to go, or if they have some sort of " bluetooth connectivity enhancer " which plugs into the serial port and boosts connectivity to keep it constant and accurate, with less data loss.
The Tilt feature would be awesome, but im guess you have to build the base version first just like any new program / software. Then add on bits and peices as the beta versions progress, to a final public release i guess.
I would love to help, if i had any knowledge in programming or interfacing.
MRXTCZ
its restrictive on what you can use to pair with it. to get around this you have to use a $90 dongle... kind of a fuckaround, and you still have a lag at the end of it. I've started working on a serial port emulation which runs on a jailbroken phone... but you'll need to jailbreak your phone first to use it.
Found this, not sure if you have already?
http://www.devtoaster.com/products/rev/
forgive my iphone ignorance, do they have a mini usb connector?
i've got a hacked navman, and seen some other examples with cool
interfaces that hook up to obdii via the mini usb.
think people have been doing similar thing on one of the palm pilots linked via some other device.
Edited by Stagea_Neo
nope.... proprietory connector, the supplied USB to iPhone connector cable can be used to connect the iphone to your PC, and access it as a camera... or with the itunes drivers installed you can access it thru itunes... or if you put it into recovery mode you can read and write from the firmware.
I was thinking something along these lines in the supplied link, wonder if you could rig up something to talk to the iphone via the proprietory usb cable to consult port.
http://www.blazt.biz/products/images/usb_cd_large.JPG
well all that does is send a regular RX/TX serial signal using the USB port. You can wire up an iphone to send and recieve this signal (uding the proprietory plug instead of the USB plug), but that level of interaction is not allowed using the factory software, you need to bypass the operating system and talk to the port directly... which you can only do in a jailbroken iphone.
and the usb would only be usb client, ie the iphone is a usb device to the PC, rather than a usb host, as in the iphone can use other usb devices like the usb consult cable.
but thats irrelevant given theres no drivers for the iphone for that usb chip (ftdi)
Not sure if you need these or not, had them in my bookmarks at work.
AppleScript Documentation
http://developer.apple.com/documentation/
welcome to macscripter.net | applescript and script resource
http://www.macscripter.net/
Apple - Software - AppleScript
http://www.apple.com/applescript/
ScriptWeb - Macintosh Scripting Resources - Since 1995
http://www.scriptweb.org/
Scripting Information
http://www.latenightsw.com/scripting.html
  • 2 years later...
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
