Well I guess I have learnt a big lesson today about guardrails, and learnt the hard way.
I hit one in my R33 and its mashed up the passenger side front guard, the bumper (repairable), bonnet and headlight.
The inside of the engine bay behind the passenger side headlight looks like a bit of a mess and it compressed in and squashed my pod filter.
There is probably suspension and structural damage although its hard to see. The car however was drivable and i had to drive it 1.5hrs to get home on the freeway and it didnt rattle or wiggle or steer funny.
I called the police and asked what I had to do and they said since:
- noone else was involved'
- the car did not need towing
- i wasnt under the influence
- i just hit the guard rail
i dont have to file a report.
Has anyone else had this kind of thing happen?
https://www.sau.com.au/forums/topic/23807-skyline-vs-guardrail/
Well I rang the Police Assistance Line because I figured if I was going to make an insurance claim I may need a police report.
Besides I didnt need to give them my name or anything to ask for advice on this.
It was thinking I might also be liable for some damages to the guard rail or something, but aparently not.
Dont think i will make an insurance claim tho, seems to be fairly managable damage.
befor claiming on insurance get sum quotes, if you claim you will need to pay the exess and the the premium will go up and you will always have to say you have made a claim when getting other insurance, in the long run you are better to just fix it your self i wouldnt think it would be 2K max for the complete fix.
Thanks for the advice dude. I will be taking it to a few panel shops around where I live tommorrow for a few quotes.
Probably not worth making an insurance claim like you said. In the long run I would end up paying 2 or 3 times the repair costs.
Originally posted by 2fardown
You made the right decision calling the police and asking for advice.  Better then getting denied when you claim on insurance.
Thanks. Yeah i also figured it would be better to be upfront to the police now and face the consequences if any than worrying needlessly about if I had broken any laws and facing some criminal charge or something.
you will be looking more like 4k to fix that damage. If its bent up around your pod, that involves beating it back into place and most likely getting it on a chassis machine. also new front bar, bonnet, light, guard + paint is going to cost. Also any suspension bits too.
best bet is too get some quotes from reliable panel beaters and then decide. Dont just go for a cheap one too as it may cost u in the end!
Thanks yeah 4k is close. I have priced up parts and stuff and im looking at about 1500 for body parts 1000 for panel beating. Then comes painting and anything else i havent discovered yet.
If you could still drive it home without it taking off in different directions then I doubt your chassis is bent.
thanks yeah, I pretty much had to drive it home. I drove it for about 1.5hrs at up to 100km/hr on the freeway. It seemed fine and didnt wobble or travel off the road by itself.
i guess i will find out tonight after the panel beater has had it all day.
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
