  • Replies 53
r32 gauge cluster SOLD
still plenty of parts left.
if your after a part and it's not listed pm me i might have one.
cheers,
Brock
r32 is now fully stripped, all parts ready to go
sold-r32 fuel tank & fuel pump-sold,
make an offer if there is anything you need.
After stereo surround/dash face-$80 complete with vents and buttons, and the cluster surround if you have it. Please send pics to [email protected]
sorry polishstorm i dont have those parts, i have a r32 accel cable if that helps?
psi parts i will send you pics tomorrow.
also r32 shell is now on ebay r32 shell on ebay
hey mate, chasing a couple of parts if youve got them.
r33 s2 steering wheel
and
r33 s2 dash piece which goes around stereo and climate control etc
and
r33 s2 plastic dash piece that goes around shifter
can you tell me availability and also price please. cheers...
  • 3 weeks later...
R32 shell-SOLD
R33 sunvisors-SOLD
still alot of parts left
i can post most things at buyers expense.
Edited by s13silvianissan
