I am about to fit a FMIC to my belove R33 Gtst and I was wondering what sort of trouble i am in for and how best to combat it. Now i know a bunch of people are going to post "just get a shop to fit it." I want to do this myself as she's my baby i have the skills and some basic knowledge for it, and I am not stupid enough to believe it will be a cake walk so to all those out there that have fitted one any tips / tricks. even if some one has a rough time frame in which it took them to do it so i can be sure to set a sufficient amount of time aside to complete the project. I know it takes me under an hour to remove the front bar the and the stock intercooler / piping. so please post if you have helpful knowlege. Thanks for reading and may your line's always find an empty lane and cheap fuel.
Edited by RandomHero83
https://www.sau.com.au/forums/topic/238181-the-saga-of-the-intercooler-begins/
have you used an angle grinder before?
doing a cooler is a pretty big step especially if you have to cut the chassis
but yeah remove the old piping and line the new piping and core up, see what modifications need to be made then get the angle grinder out
edit: my mate who's never done it before took about 4 hours with me occasionally answering questions so yeah get up at 10 on a saturday and give it a shot
Edited by gfunkk
Yeah I have, more times than i care to remember.
Yeah I will be doing that several times before i go cutting and welding anything. it's a sound piece of advice thanks mate.
What kit have you got and which way does the piping run?
It all depends on the Intercooler that you have to fit, with mine i had to decide whether to keep the factory aircon radiator or cut the front reo.
if ya need a hand man give me a shout, i got mine in, so i can bring it around 2 show u.
but the suts they done were really dodgy.
yeah dude might need a set of hands that don't wander off when bold and the beautiful or some other crap comes on tv.
i'd say i have enough clearance in the front as i am also running a 400R front bar but until it arrives it's only pics i can go by. seen a few people have done it the way you mentioned trying to avoid relocating too much and cutting her up if i can.
Make sure your new piping (if not using a stealth kit) has a nipple in it.
The kit I put on didnt have it, so i drilled a hole and put one in.
Other than that, I had to take about 1cm off the reo bar, cut out the fog lights, cut back parts of the thermo fan, trim the front bar a bit and cut the hole in the wheel arch.
I threw mine in when i had the stock bar on didn't have to trim a thing went in like a hand in a glove. Only had to cut a hole in the r/h side of the chassis under the washer bottle for a pipe, but the material was thin as butcher cut it a little with the screwdriver and hammer, went like a hot knife throu butter. For that pipe cos it was U shaped i used a piece of cardboard to get the hole in the right place. I have a 400r bar on mine now and clearence is still not a problem.
The deed is done the FMIC is in. OMY-33 comae round and wefitted it in a few hours. wasn't too much of a pain in the ass I am going to have to do some cean up where we had to cut it for pipes. but thanks for the advice guys and thanks for the help OMY-33 +1 rep. The only question left is should I do an ECU reset?
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
